Project idea
Old Mar 31, 2011 | 09:40 PM
InSnVpR_719's Avatar
InSnVpR_719
Project idea
So I was home leave last week, and while my family was having a pleasent dinner conversation about camping and off raoding with my 1976 jeep cj5. My dad brought up replacing my original 238 and putting a ford 300 straight six in it. The complications that we started to think about are... one motor mounts but that would be an easy fix...two and the biggest i dont want to replace my trans at all so my main reason for me posting this is to see if anyone knows the exact bolt pattern for the 300 ci engine and the t18 4 speed trans bell housing.... is there any mods i would need to do or will it work at all
Old Mar 31, 2011 | 09:54 PM
KevinGnWV's Avatar
KevinGnWV
The village idiot.
A 4.0 HO is a common swap and well documented but that's for Jeep forums.
If you want a 4.9 "just because", you may find a trans adapter at advance adapters, may even have engine mounts, but I've been in the Jeep crowd before and that swap I've never seen. Usually SB GM engines and the above mentioned Jeep 4.0 HO.
Old Apr 1, 2011 | 04:20 PM
cadunkle's Avatar
cadunkle
If you're gonna go through that work to do the swap I'd say do a 302 or 351w. No reason to replace one turn with another.
Old Apr 1, 2011 | 09:33 PM
desperado_18_2000's Avatar
desperado_18_2000
You can probably get away with changing the bellhousing on the T-18, as ford used the same trans behind the 300 six. Other than that its going to be the little details to figure out, such as starter, a little wiring, etc.
And don't give into the bent-8 obsession, the 300 will do you just fine.
Old Apr 1, 2011 | 10:09 PM
cadunkle's Avatar
cadunkle
It's not significantly cheaper to build a 300 six, if anything I'd expect it to be more costly since parts are likely more expensive. For similar cost you have have a lot more torque from a small block and I'd expect a similar amount of work involved in the swap. Hell, if a 460 will fit easily in that engine compartment go that route, but I think that swap would likely make it more complex and expensive compared to a small block.
Old Apr 1, 2011 | 11:12 PM
KevinGnWV's Avatar
KevinGnWV
The village idiot.
You can have too much torque before you need to start swapping out drivelines too. I see your point, but I thought long and hard about putting an EFI 300 in my CJ. Pluses would be, torque at idle, efi for extreme angles and deep water, less likely to overheat, reliability (huge factor) and again, not so much power you tear apart transmissions and rearends. In the end, I went with an efi 4.0 HO, which is why I answered the original post.
Old Apr 2, 2011 | 12:40 AM
ctubutis's Avatar
ctubutis
The 300 I6 shares the same bell housing bolt pattern as the 302 & 351W (and several
others):
List of Ford bellhousing patterns - Wikipedia, the free encyclopedia
I've never done this swap but a quick Google shows different input shaft lengths as well
as bolt patterns between the Ford & Jeep T18s:
Borg Warner T-18 Transmission Diagrams and Information
The Ford version uses the standard Ford "butterfly" bolt pattern and a 1 1/16" 10 spline input shaft. The input shaft is around 6 1/2" long. The input shaft is about 1/2" shorter than the Jeep T-18 input shaft...
...Ford T-18s have a slightly different bolt pattern than most Jeep T-18s. The drivers side lower bolt is lower on the Ford version. The Ford pattern matches the T-150 and T-176.
Let me google that for you
Jtmtree
Feb 13, 2015 09:07 PM
granny_rocket
13
Mar 31, 2013 10:55 PM
kedwinh
Jul 18, 2011 11:43 PM
wrecks1
Nov 12, 2002 08:17 PM
Dale Lane
Jan 18, 2000 02:26 PM
