dipstick question??
Old Mar 16, 2011 | 03:25 PM
80stepper's Avatar
80stepper
dipstick question??
ok i had to break the dipstick mount to the manifold off to put my headers on because the jam nut was stripped. here i figured i had a 302 in the garage id just grab it off that one.. nope it has it in the front.. mine has i nut like going into the oilpan on the driver side.. so online i went and i saw lokar had a 1/4" npt flexible stick and tube $80. so i called parts bin dot com and he shipped me one that he said would work it came and i think its a push in style? is that what i have or can it work with this nut in my pan?? thanks for ny and all help.. its been a long week chasing dipsticks!!
Old Apr 1, 2011 | 03:18 PM
80stepper's Avatar
80stepper
this is what i got.. is it screw in or push in.. cant take it out till i have the correct replacement!! please help..
Old Apr 1, 2011 | 04:56 PM
dohc_chump's Avatar
dohc_chump
This space for rent...
You have the screw in style. 3/8" flarenut and a JY dipstick would of fixed you up.
Old Apr 1, 2011 | 05:06 PM
80stepper's Avatar
80stepper
ok great.. now where do i find this part.. i have seen 1/4" npt and push in.. thanks i never saw this type..
Old Apr 1, 2011 | 05:17 PM
dohc_chump's Avatar
dohc_chump
Auto parts store. I pulled mine off some extra 3/8" fuel line I had laying around. For mine, JY push-in type dipstick tube off a 302, cut off the push-in end, slid on the flarenut, and flared the end of the dipstick tube. Helps to check your oil when properly filled before removing the old dipstick and mark it. I only say this, because I ended up using a JY dipstick off, uh, erm... something Ford, but not a truck and used the old dipstick to mark the new.
Sorry it's hard to see with all the mud, but it's in there.
Old Apr 1, 2011 | 06:22 PM
80stepper's Avatar
80stepper
ok soo i have a new pushin style i ordered .. if i remove my old one and cut the bottom off the new one, install the flare nut from old one flare the new one and install and add a new oil change.. 5 qts. and see where it reads i should be good?? adjustment with either the tube or make a mark on the dipstick for full.. correct.. thanks for this help!!
Old Apr 1, 2011 | 07:05 PM
TheKirbyMan's Avatar
TheKirbyMan
Get your oil level where it needs to be before removing the old dipstick setup. Your current dipstick will show you where the level needs to be.
If you change the oil, you'll have to add or remove a little to get it where it needs to be, and with the new dipstick, you won't know where that is yet.
Old Apr 1, 2011 | 07:26 PM
Ken Blythen's Avatar
Ken Blythen
Also, that should be 6 quarts total, allowing for the filter volume.
Old Apr 1, 2011 | 07:47 PM
80stepper's Avatar
80stepper
well you see when i took off the stock manifolds the jam nut on top of the manifold bolt stud was too rusted and i just twisted the dip stick and tube around till it broke leaving it unable to be removed to get a reading.. (yeah dumb move).. i did forget about the filter too. six will be a fill mark if i just keep it a hair below most times till i rebuild it later and change the pan.. once i find one of them also a tuff piece to locate for the 4wd.. thanks though i think im on track.. ill take it off tomorrow and see what i got..
Old Apr 2, 2011 | 12:18 AM
dohc_chump's Avatar
dohc_chump
Look up an oil pan for a 79 Fairmont with a 302, Dorman part #264-023.
Old Apr 2, 2011 | 03:46 PM
emkay4597's Avatar
emkay4597
you can still use your old dipstick, just unscrew it when ready to remove (tube and all)and read the level. compare that to the new setup.
i made my new one a tad shorter with a plumbing pipe cutter while it was mounted until it was where i needed it.
Mowing Man
Apr 17, 2013 07:55 PM
33homerdoodle
Nov 1, 2012 04:15 PM
art015
Apr 27, 2010 09:00 AM
RubberDuck
31
Oct 23, 2008 11:58 PM
LCA078
Oct 30, 2007 09:10 PM
