Truck's a turd!!
Old Mar 28, 2011 | 10:24 PM
Izzy351's Avatar
Izzy351
Where's your boost at again?
Old Mar 28, 2011 | 11:09 PM
bulla's Avatar
bulla
In stock with my waste gate hooked up wot at 20 lbs, with it unhooked it's at 24 lbs. This is on stock. It will boost much higher with the tunes, like 28-30.
Old Mar 29, 2011 | 06:04 AM
Kwikkordead's Avatar
Kwikkordead
When does it hit 20 psi in stock tune? at 3000 rpm or more like 2300 to 2500?
Old Mar 29, 2011 | 06:55 AM
bulla's Avatar
bulla
Not sure Dan. When I get ot back together I'll let you know. Still putting the brakes back together!
Old Mar 29, 2011 | 07:47 AM
bulla's Avatar
bulla
I know for a fact this truck had a chip on it before I bought it and had already had some of the intank mods done. Ice had the truck for just over a year now and put 20,000 miles on it. To me it runs the exact same way as when I bought it. The current mods I gave on it are the HPX, FRX, WW, 6637, big boost boots, , int bellowed up pipes and 4-5" exaust turbo back. Also the .50 mod has been done and the #8 ll injector has a normal ad in it's place.
Old Mar 29, 2011 | 07:58 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Just to say, . I'm leaning more to something electrical that is wrong with your truck.
Old Mar 29, 2011 | 08:17 AM
Kyle_KleinSS's Avatar
Kyle_KleinSS
Originally Posted by F350-6
I wouldn't assume they're related. Keep an open mind. You're brakes aren't dragging are they? Stuck slide pin maybe? Carry a bunch of weight in the truck all the time?
By the way, anyone know what the stock 0-60 time is just so we have it for comparison purposes.
I myself have been chasing a mpg issue like this. I have a right side pull when I brake. I was told to relube the slide pins. Also the right rim will have more brake dust on it than the driver side. How do I check for sticking brakes? Maybe bullas and my issue could be similar
Old Mar 29, 2011 | 10:13 AM
bulla's Avatar
bulla
I guess we'll find out once I finish the brakes. I'm not to sure on how to tell if a caliper is bad but the slide pins, if bad they just won't move. Maybe my brakes could of had something to do with it, heck after spending almost 700 bucks on front and rear brakes and rear axle bearings I'd be tickled pink. And here lately I ain't been to tickelish!
Old Mar 29, 2011 | 10:16 AM
bulla's Avatar
bulla
Originally Posted by miller_feed
Just to say, I did the 60 mph in 2.0xx seconds. I'm leaning more to something electrical that is wrong with your truck.
You know Rick I've been thinking with the truck having the chip and some intank mods done I'm starting to wonder if someone might of gotten into the idm and fudged with something! Guess there's one way to find out!! Haha
Old Mar 29, 2011 | 10:17 AM
bulla's Avatar
bulla
Has anyone ever experienced any ill effects after trying an idm mod?
Old Mar 29, 2011 | 10:19 AM
Kyle_KleinSS
Im going to check my slide pins today. Ill let you know later this week if im getting better mileage. Im not counting on it but Ive been suprised once or twice before
Old Mar 29, 2011 | 10:59 AM
miller_feed
You may as well get into the IDM, you've torn into everything else. Get one from one of the shop trucks and see what happens.
Old Mar 29, 2011 | 12:31 PM
  #28
bulla's Avatar
bulla
Ok after $387 for just the pads and rotors I'm probly closer to 8or 900 bucks now!!
Old Mar 29, 2011 | 12:40 PM
  #29
joeyd61's Avatar
joeyd61
Bulla, are you using a "boost fooler"?? our trucks will defuel @ 21 or 22 psi?? I know befor i installed mine the truck would fall on its face..when this happins the CEL comes on breafly..
Old Mar 29, 2011 | 12:49 PM
  #30
bulla's Avatar
bulla
Oh yea, I forgot. I do have an OCR!
