Truck's a turd!!
Old Apr 18, 2011 | 11:06 AM
  #136
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
ok i know you did a pcm and idm swap and i think you swapped out ipr or icp's but which one was it? did you use a new ipr or rebuilt one? did you replace both the ipr and icp at the same time?
Old Apr 18, 2011 | 11:26 AM
  #137
bulla's Avatar
bulla
Replaced icp and ipr, both were new. Now I have my new icp in and my original ipr in since the new one was damaged in one of my pump failures.
Old Apr 18, 2011 | 11:34 AM
  #138
bulla's Avatar
bulla
This is 0-70 in 80 econo. It doesn't build near the pressure.http://www.youtube.com/watch?v=5rF-iQOs7fI
Sent from my iPhone
Old Apr 18, 2011 | 12:23 PM
  #139
Shake-N-Bake's Avatar
Shake-N-Bake
David,
I assume the manual gauge was hooked up to the right bank, correct? Did you monitor the ICP with AE while making this run? If so, how did the pressures compare?
Old Apr 18, 2011 | 01:06 PM
  #140
bulla's Avatar
bulla
I data logged both runs but I can't recal the numbers. I'm not sure how to post a data log either. But I'll take a look tonight!
Old Apr 18, 2011 | 01:14 PM
  #141
JT250's Avatar
JT250
Print the data log as a PDF (adobe). If you don't have that as an option you may be able to download a PDF printer online (software). Then it will be a picture that you can post like all the rest.
Old Apr 18, 2011 | 01:33 PM
  #142
Shake-N-Bake
I struggle with the data logs as well. I've found it's best not to monitor too many parameters at once because it's just too much information for AE to handle (or perhaps it's the data connection itself...)
What you can do is just look at the time stamp on your data log and cross reference to the time stamp on your video. This will help you to get your data log to align with the video so you can compare the readings at several points.
If the readings from AE vary substantially from the temporary gauge then your next step would be to connect the gauge to the left bank and see if the readings are the same. If the gauge reads the same on both banks, and there is a variance from what AE sees, then you will need to verify if the gauge is accurate. (not sure how to do that exactly...) Maybe the PortaPower can be used to check your gauge calibration?
At any rate, if the readings are different from bank to bank then you can look into that issue a bit further.
If the readings are the same from bank to bank with a verified calibrated gauge and AE is showing something else, then you need to look at the ICP wiring in more detail. Is there a possibility that a previous owner attempted some sort of resistor mod on the ICP wiring? If so, wouldn't that cause all kinds of problems with the custom tunes?
Old Apr 18, 2011 | 08:46 PM
  #143
bulla's Avatar
bulla
Ok guys I dud not data log it but I did notice when the pressure drops from 3000psi-2500psi on the mechanical gauge, it does drop on the ae from 27-2800psi to about 2400psi. When that pressure change happens the duty cycle drops from 40%-32%. some mentioned it had to do with when I shift so I kept it in drive with the od cancel button in the off position and again the pressure dropped and would not come up till I let off and floored it again.
Old Apr 18, 2011 | 08:51 PM
  #144
bulla's Avatar
bulla
Also I was playing in the 60 tow tune and if I floor it the pressure would drop but if I let off a lil then get back into it my pump actually registered over 3000 on my ae and duty cycle at 64%. strange!
Old Apr 18, 2011 | 08:56 PM
  #145
99hunter's Avatar
99hunter
Sounds stupid but have you tried a tps? Maybe it has some bad contact in it.
Old Apr 19, 2011 | 07:19 AM
  #146
JonathanN's Avatar
JonathanN
Have you got an OCR, Dave? I can't remember if you have a boost fooler or not. Kinda sounds like defueling. But with your sticks acting like they are, spitting oil like that, I still don't think they're right.
I've been getting your calls... been working as of late. I'll call you back ASAP.
Old Apr 19, 2011 | 03:56 PM
  #147
clem1226's Avatar
clem1226
have you ever looked at transmission data on the AE such as torque slip, temp...
you have been over the motor with a fine tooth comb maybe it is time to look elsewhere.
Old Apr 19, 2011 | 09:33 PM
  #148
bulla's Avatar
bulla
Ok guys that dip in pressure happens at 3000rpm's. Maybe they are supposed to do that. I also hooked the gauge to the driver side and it's showing the same results.
Old Apr 19, 2011 | 09:40 PM
  #149
bulla's Avatar
bulla
On a side note, I need a turbo for towing! Van or 38r? I
Guess cause my truck is so
Heavy it puts an extra strain on the turbo. Even with a ww I still had trouble with surge. I think that's what wore my other turbo out like it did! I towed my tractor today and couldn't even use my 80 tune, all it wanted to do was surge. Then in my 60 I still had to watch how I accelerated cause it would surge.
Old Apr 19, 2011 | 09:57 PM
  #150
JT250's Avatar
JT250
I was getting surge the other day in 80t pulling around 5k. I have a ww also but mine is a srw short bed 4 door. I had a strong head wind though.
