Truck's a turd!!
Old Mar 31, 2011 | 03:24 PM
  #46
Franko72's Avatar
Franko72
Molon Labe
If you want your motor as clean as Ricks, your going to need alot more soap...
Old Mar 31, 2011 | 03:42 PM
  #47
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Frank, I don't think David is worried about how clean his engine is untill he can get to the speed limit in less then 5 mins.
Old Mar 31, 2011 | 03:45 PM
  #48
99hunter's Avatar
99hunter
I don't know if this has been touched yet but if you EBPV was hanging up partialy you would see ok boost probably higher egts and it would be a pooch.
Old Mar 31, 2011 | 04:00 PM
  #49
99hunter's Avatar
99hunter
Old Mar 31, 2011 | 09:24 PM
  #50
bulla's Avatar
bulla
Ebpv has been gone for a
While now. But I did remove the idm today to check for moisture or some sign of it being bad, but it looked good. So I resealed it and I'll still probly swap it anyhow. I'd hate to have to buy one, Ford wants $600 for one!! Also I've been noticing my ipr DC has been getting higher, I let my truck lug today and got in it and the dc went to 64% and threw a cel. I couldn't get it to duplicate it but at wot my icp is around 1,600-1750 and my dc can climb as high as 50%.
Old Mar 31, 2011 | 09:28 PM
  #51
JonathanN's Avatar
JonathanN
And thus begins the saga of no ICP again... I wonder if you hadn't ought to try another ICP sensor? Or have we been through this already...?
Old Mar 31, 2011 | 11:04 PM
  #52
bulla's Avatar
bulla
Yea Jon it's new, but hey I guess you never know!
Old Apr 1, 2011 | 12:19 AM
  #53
bluescrew's Avatar
bluescrew
and theres no codes ?
Old Apr 1, 2011 | 08:42 AM
  #54
Kwikkordead's Avatar
Kwikkordead
You HAVE to be bleeding HPOP pressure somewhere.
Old Apr 1, 2011 | 08:45 AM
  #55
JonathanN's Avatar
JonathanN
Is it possible for for a head to crack in a way that would bleed the oil back into the pan? Also, is there anything in the front of the motor that can brake and cause bleeding?
Old Apr 1, 2011 | 09:04 AM
  #56
Kwikkordead
ANYTHING is possible.
Old Apr 1, 2011 | 09:25 AM
  #57
clem1226's Avatar
clem1226
what kind of MGP numbers are you seeing on the AE? Does the MGP on the AE follow along with your boost gauge?
I'm wondering if you have an intermittent MAP sensor or if there is an issue with the wiring for the map or the MAP circuit in the PCM.
I bent the a pin over pulling my PCM and the only symptom was LOW power...when scanning with AE I had 0 MGP reading from the MAP.
Old Apr 1, 2011 | 12:44 PM
  #58
bulla's Avatar
bulla
What is mgp? Also i haven't swapped my hpop yet but I need to! It started making the same noise before the first one went out.
Old Apr 1, 2011 | 04:38 PM
  #59
mueckster's Avatar
mueckster
Manifold Gauge Pressure
Old Apr 1, 2011 | 04:41 PM
  #60
JonathanN's Avatar
JonathanN
I'm pretty sure Dave said he replace his map sensor...
