what upgrades did the e4od recieve in 1995?
Old Mar 27, 2011 | 08:35 PM
xavier23's Avatar
xavier23
Which parts are upgraded from the factory on 1995-up e4od transmissions?
Old Mar 28, 2011 | 01:42 AM
86F150302's Avatar
86F150302
https://www.ford-trucks.com/forums/5...d-upgrade.html
E4OD change different connector - FSB Forums
Old Mar 28, 2011 | 09:02 AM
rla2005's Avatar
rla2005
Ford also moved the solenoid protection diodes from the solenoid pack to inside the PCM. If you want to use a later model transmission in a pre-'95 truck you have to use the older solenoid pack or use a 95+ PCM.
Old Jul 3, 2013 | 05:37 PM
Rentaro's Avatar
Rentaro
I understand how to swap out the solenoid pack, but I heard the computer has improvements to the shifting in the later year.
I am upgrading my 1990 F250 7.5L 460 E4OD 4x4 to an E4OD that came out of a 1995. What all would be involved if I wanted to swap out my 1990 PCM for the 1995 PCM? is it a simple plug and play?
Old Jul 4, 2013 | 01:20 PM
jas88's Avatar
jas88
The most important upgrade was a bigger pump. You can do fine with a pre-95 E4OD as long as you swap to a 95-up pump. If you have it all apart, upgrade the center bearing support as well. Otherwise, the pre-95 stuff is fine in my experience.
Old Jul 4, 2013 | 05:50 PM
rla2005's Avatar
rla2005
The ignition system changed in 1994. Swapping in a 1995 PCM into a 1990 would also require a black colored CCD-style Ignition Control Module and some wiring changes to run it.
I have never heard there was an overall change in transmission programming on later model year trucks. It's a swap that will most likely only drain your wallet. If you want firmer shifts install a transmission valvebody from ThePunisher.
plowboy1986
Nov 24, 2016 07:34 PM
ptt
Jun 2, 2009 01:14 AM
javi2001
Sep 8, 2007 03:18 PM
delostruck
Nov 16, 2006 01:07 PM
