e4od or 4r70w
Old Nov 16, 2006 | 12:37 PM
delostruck's Avatar
delostruck
Question e4od or 4r70w
how can i tell the diffrence between a e4od or 4r70w in my 1995 f-150 4x4 5.8l
Old Nov 16, 2006 | 12:49 PM
Tennesseepowerstroke's Avatar
Look in the drivers door ID tag and see what the transmission code is. Look in you owners manual and it should tell you which transmission this code identifies. I would think it would be the E4OD as this was a heavier duty transmission and you have the 5.8L. I think the 4R70w was mainly used with the 302 v8 and the 300 6 cylinder.
Old Nov 16, 2006 | 01:07 PM
Casey's Avatar
Casey
The easiest way to tell is that the 4R70W was never mated to the 5.8L. If it is an automatic with overdrive it has to be an E4OD.
CMGALLAMORE
1997 - 2003 F150
Jan 16, 2026 01:34 AM
RIKIL
43
Jan 14, 2017 09:39 PM
rcn
27
Jan 5, 2010 05:58 PM
CT
Feb 9, 2005 08:51 AM
jberylecrider
Aug 24, 2002 06:13 PM
