firewall tag
Old Mar 27, 2011 | 07:06 PM
75styleside's Avatar
75styleside
firewall tag
i pulled this tag off the center of the firewall on the engine side right behind the air cleaner. i know the top row of numbers is the vin and the shift in the plant.
f11yrv45376 10-38
yx 133 bdy 4 wde rhsm 133 is wheel base
u8 comb rpo c us u8 is color code
3x e 7 aft
i can not find a chart to say what the name of the color code u8 is. can someone help? the color of the dash is the same as the id tag i have pictured.
so i dont know how to add a photo if someone can help with that as well.
thanks
Old Mar 27, 2011 | 07:27 PM
mikeo0o0o0's Avatar
mikeo0o0o0
That's a "buck" tag. It was used by assy line workers to insure the proper parts were installed durring manufacture.
While some info can be decoded, there is no actual way to decode the buck tag like you can decode the warranty plate.
As for the color code, what year is your truck. The same codes are used for different colors durring different years.
Old Mar 27, 2011 | 07:43 PM
mikeo0o0o0's Avatar
mikeo0o0o0
If your truck is a '75 (s/n V20,001-X40,000) then the color code "U8" is (U) Light Green,
(8) Dark Yellow Green Metallic.
Old Mar 27, 2011 | 08:45 PM
75styleside
yeah its a 75. so the light green its that the interior color or is this truck a two tone truck?
Old Mar 27, 2011 | 10:11 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Double digit color code means two tone.(DUHH!, I should have picked up the year of your truck from your screen name.)
Old Mar 27, 2011 | 10:53 PM
75styleside
ok. thanks for the info. its always nice to know more about the truck.
Spaught
Apr 3, 2016 12:11 PM
jah65
Jan 20, 2011 04:26 PM
Shane in WI
31
Jan 7, 2010 09:34 PM
flcracker9
Jun 30, 2008 05:47 PM
rondo74
Dec 22, 2001 09:15 PM
