1974 F100 Getting intermittent spark and wont start
Old Mar 23, 2011 | 03:46 PM
EWHOLTZCLAW's Avatar
EWHOLTZCLAW
Hey whats up all! My 74 wouldnt start the other day at work and i had to tow it home. when i got it home i checked for spark and im not getting any. I know im getting gas cause i can see it go into the carb when i look in there and push on the gas. so anyway i wasnt getting spark so i left it on the charger for a while and tried it again later and just cranked and cranked and it tried to start a couple times and then it did start once and idles fairly rough for a couple seconds and died again. about a month and a half ago i put new plugs, wires, cap, rotor, points, and condensor on it so i figured the coil is probably the problem so i ordered one and it hasnt showed up yet but i have a feeling something else may be the problem. Its got the 390 in it. Any other ideas?? im hoping the coil shows up on friday its an MSD from jegs.
Old Mar 23, 2011 | 09:50 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Replace the coil like you plan. Also, double check the point gap, be sure it hasn't closed up. Did you put a small amount of lube on the distributor cam? If the distributor cam is dry, the points rubbing block can wear rapidly allowing the point gap to close up. If that doesn't fix the problem there are three other things I would check.
First, it could be a bad condenser. These can have the same symptoms as a bad coil. They are relatively cheap. Even though you just replaced it, it could be bad.
Second, there is a small bare ground wire inside the distribrutor. This grounds the breaker plate. IIRC its attached to the points. Be sure it hasn't broken and is correctly connected.
Third, the breaker plate is two pieces, these were notorious for going bad. The pivot disintegrates and allows the points to move around. This throws the point gap out of kilter.
Old Mar 24, 2011 | 07:32 PM
Ford-2-the_core's Avatar
Ford-2-the_core
how long it been befor any major work if never it could be a bad timing chain 9/10 time that is what it leads up to be when it happens to me
Old Mar 24, 2011 | 09:50 PM
fmc400's Avatar
fmc400
MSEE
No offense, but I have no idea what you just said.
Old Mar 25, 2011 | 12:34 AM
Ford-2-the_core
how long has it been since you had any major work?
If never.
It could be a bad timing chain 9/10 time that is what it leads up to be when it happens to me
Ok is that better sorry Grammer was never a strong suit of mine. But I am working on it
Old Mar 26, 2011 | 08:41 PM
EWHOLTZCLAW
Hey thanks Mike. I replaced the coil and reset the points and its runnin like a champ in fact its sitting in the parking lot at work right now so we will see how she starts in the morning. I think on payday or something i might just go ahead and replace the whole distributer. The coil i bought is a MSD blaster 2 so i was thinkin i would just get an msd distributer also. Any ideas?
Old Mar 27, 2011 | 10:27 AM
mikeo0o0o0's Avatar
mikeo0o0o0
I don't have any personal experience with MSD's products. I do know they are popular and have a good reputation though.
Old Mar 27, 2011 | 02:49 PM
EWHOLTZCLAW
Cool well i think ill give it a shot, only one way to find out eh? Thanks again for the info man, i appreciate it.
Old Mar 27, 2011 | 03:20 PM
montana_highboy's Avatar
montana_highboy
You have points in a '74? consider a Pertronix unit, it's very popular with the '67-'72 crowd.
Ignitor
Old Mar 27, 2011 | 10:27 PM
EWHOLTZCLAW
Ignitor
Hey thanks man. I do have points and that would be sweet to change it out to something like that. that list has like 360 different ones do you know what one i would need? its a 390ci
Old Mar 27, 2011 | 10:58 PM
montana_highboy
For your application it's part #1281 you can shop for a better price, i just pulled this up on a quick search to find the correct part number...
PerTronix 1281 - PerTronix Ignitor® Solid-State Ignition Systems - Application - SummitRacing.com
Old Mar 27, 2011 | 11:18 PM
EWHOLTZCLAW
That rocks, thanks a ton man. Ill try and get one ordered here in a few days and se if i cant get er hooked up.
Thunderbird7480
Feb 9, 2020 02:51 PM
exidor12
Sep 13, 2015 06:34 AM
bryanmartin
Sep 7, 2015 05:24 AM
Ndurbin10
Apr 1, 2014 07:17 PM
WoodHeat
41
Aug 24, 2012 08:34 PM
