noise
Old Dec 26, 2002 | 07:36 PM
1988ford's Avatar
1988ford
noise
I have a 1988 302 that has a brand new motor new belts, hoses, everything...but there is a squeak sometimes. It only squeaks on wet mornings. If it has rained alot that night it will make that noise for awhile after I drive it but it is not really wet out it will stop after a few miutes. What could this be? a pulley?
Old Dec 26, 2002 | 07:51 PM
PATS2002's Avatar
PATS2002
noise
[updated:LAST EDITED ON 26-Dec-02 AT 08:52 PM (EST)]Belt tensioner. When you start it and it makes the noise spray it with wd-40, also spray idler pulley as that also could be a source of ypur noise. I had the same issue with my truck. It will eventually get to the point where it does it all the time.
Old Dec 26, 2002 | 07:55 PM
1988ford's Avatar
1988ford
noise
Will it stop if I spray the belt tensioner with wd-40 and if it does is that what is making the niose?
Old Dec 26, 2002 | 08:22 PM
PATS2002's Avatar
PATS2002
noise
Temporarily it will stop but it will come back eventually. Yes thats what is making your noise(whatever you spray and quiets) the tensioner most likely is the culprit. the tensioner is about 50 or 60 bucks from napa.
Old Dec 26, 2002 | 09:23 PM
big_josh_c's Avatar
big_josh_c
noise
Ericwlod
6.7L Power Stroke Diesel
Nov 12, 2014 08:58 AM
88_F0RD
13
Apr 4, 2014 04:55 AM
lee
Feb 14, 2014 04:10 PM
goatdriver
2004 - 2008 F150
Jun 3, 2007 07:47 PM
hobbyman
1983 - 2012 Ranger & B-Series
Jan 26, 2004 09:24 PM
