water pump problem? (97 Ranger)
Old Jan 26, 2004 | 01:02 PM
hobbyman's Avatar
hobbyman
4wd Low
I have a 97 Ranger with 3.0 v6
I replaced the coolant just the other day. After doing that
I now have a squeak. It is not the noise you hear if belts
are slipping or get wet. I have driven it several times to see
if continued and it hasn't stopped.
Could a simple thing as replacing coolant have caused a
problem with the water pump?
If it is the water pump does anybody know of a web site that
has the steps for replacing it?
Old Jan 26, 2004 | 01:20 PM
84ford460's Avatar
84ford460
Hobbyman,
Sounds like it could be the waterpump bearing. Is there any coolant leaking from the seep hole on the pump. If so, you need a new pump. If not try adding some barsleak or the like to the coolant to lube the bearing.
As for the replacement your best bet is to get you a Haynes or Chiltons Manual. I prefer the Haynes.
Larry
1996 Ranger XLT Ext. Cab 4x4 4.0L
Old Jan 26, 2004 | 01:51 PM
hobbyman's Avatar
hobbyman
4wd Low
Thanks.
I haven't seen a leak and I have already put in the
barsleak.
I guess I'll have to replace the pump.
Does anybody have an idea as to why changing coolant
might have caused this?
Old Jan 26, 2004 | 04:31 PM
87 XLT's Avatar
87 XLT
It's amazing the metalic/bad bearing sounds that a bad belt can make. Try spraying a little water on the belt & see if the noise goes away. A couple years ago I thought I was hearing a bad water pump bearing on my 87 2.9. Sprayed a little water on the belts and the noise went away. Changed the belts & no more noise.
Old Jan 26, 2004 | 09:24 PM
hreed's Avatar
hreed
Bars Leak should be the last resort. Especially if you didn't have a leak. It could be a coincidence, but maybe the water pump bearing, alternator bearing, power steering pump, or belt is making the noise. Try the water trick to see if it goes away. Does it do it at idle. If so, pop the hood and listen for the noise. Just changing the fluid should not cause a problem.
cixelsyd
1997 - 2003 F150
Mar 16, 2012 11:17 AM
xtmsports
Jan 12, 2010 08:28 PM
71FoMoCo
Jul 19, 2007 03:30 PM
silan
Aerostar
13
Dec 4, 2006 04:40 AM
TexasGuy001
Oct 26, 2005 01:32 PM
