I wish I could tell you. Mine occassionally takes spells where it cranks and cranks and refuses to start without leaving any kind of code. Stop, let it sit for 10 seconds, and it fires like a gasser. Very very strange.
You could still have air working through the HPO system, but check the simple things....FICM plugs, etc and check it for codes.
Yes, I did check for codes, and for some reason my SCT wont read codes until I try it 3 or 4 times.
I check everything I could without getting pissed for it not wanting to start.
What kind of socket like an o2 sensor type of socket?
What size? Wouldnt hurt to take it out and clean it right?
Yes, exactly but this socket has a cut up the side because the connector is at a right angle. Not sure of the size since I did mine while the turbo was out--LOL--and I used a big *** crescent wrench.
