Something weird happened today..
Well it didn't take me long to come back and post something up....
Well this morning truck started up GREAT, ran great, no problems, got to work let it idle for a minute or 2 and shut it off... Well 9 hours later I went to start it up, crank,crank,crank, nothing. First things first, checked fuel in secondary filter good, injector buzz good. Cranked and cranked some more and nothing.... then I checked all fuses jiggled some relays around, batteries were just about dead, cranked it over again and bam started up like a champ.. Now, I doubt there could still be air in the system, but what could have stopped if from starting after running great when I went to start it back up? hmmm.... |
trash in the ipr
I wish I could tell you. Mine occassionally takes spells where it cranks and cranks and refuses to start without leaving any kind of code. Stop, let it sit for 10 seconds, and it fires like a gasser. Very very strange.
You could still have air working through the HPO system, but check the simple things....FICM plugs, etc and check it for codes. |
Injector pressure regulator?
Thats underneath the turbo correct? Maybe a oil change might help? Also, I added sea foam to the oil on Sunday. |
Originally Posted by npccpartsman
(Post 10121102)
You could still have air working through the HPO system, but check the simple things....FICM plugs, etc and check it for codes. I check everything I could without getting pissed for it not wanting to start. I also did think air in the hpo system |
Originally Posted by 2006powerstroke90
(Post 10121109)
Thats underneath the turbo correct? Maybe a oil change might help? Also, I added sea foam to the oil on Sunday. Yes, underneath the turbo. |
Also check your ICP connector. Is it wet? Take it off and replug it snug.
Originally Posted by 69cj
(Post 10121176)
Icp sensor..right pass side valve cover towered the front of it? But it was raining out on my way to work and it just stopped when I went to start my truck. Taking the turbo out again does not sounds good to me. |
You don't have to remove the turbo, you just need a special socket.
Oh really? That sounds much better.
What kind of socket like an o2 sensor type of socket? What size? Wouldnt hurt to take it out and clean it right? |
Not for an 06. Just unplug it and see if it starts.
(Post 10121252)
Where exactly is the icp sensor? |
(Post 10121251)
Well taking the turbo out is a breeze now, I don't don't like lining the up pipe back up.
I would like to do this tomorrow. Anyone know that size? And if its gummed up it should be noticeable? What should I clean it with? |
(Post 10121311)
