Something weird happened today..
Old Mar 21, 2011 | 07:30 PM
lakewood's Avatar
lakewood
Originally Posted by hubler13f
I used a 36mm hub socket and cut a slot out of it with a cutting wheel. It sucked to trash a $30 socket but I have it for later I guess.
This is off subject, but you pain 30 bucks for a 36mm socket!! I bought one at advanced auto parts for 12 bucks, i use it for the fuel filter and oil filter caps
Old Mar 21, 2011 | 07:40 PM
2006powerstroke90's Avatar
2006powerstroke90
So would a 36mm wrench work?
Ill see how it starts tomorrow morning.
I plugged it in, it's still getting pretty cold at nights here. 25deg
Old Mar 21, 2011 | 07:59 PM
2006lariat's Avatar
2006lariat
25* isnt that cold, It should fire right up at 25*! I had to plug mine in at 25* to get it too start, but my FICM was bad! I am curious as too why you are cranking long at times, as my truck cranks long too! I have to crank mine for 3 or so seconds, let up, than crank again. It usually starts with in 3seconds on the 2nd starter cycle! Wonder if my IPR sensor is going?
PS I have been following all your threads, and you got way more patiance(?) than I do! I hope your on the downhill side now!
Last edited by 2006lariat; Mar 21, 2011 at 08:06 PM. Reason: wrong sensor initial's
npccpartsman's Avatar
npccpartsman
I got a 1/2" drive 36mm Craftsman socket for $6 in 2004. Probably a little more than that now.
Old Mar 21, 2011 | 08:01 PM
npccpartsman
Originally Posted by 2006lariat
! Wonder if my ICP sensor is going?
IPR would be the suspect, not the ICP.
Old Mar 21, 2011 | 08:04 PM
2006lariat's Avatar
2006lariat
Sorry their are so many ipr, icp, ficm, ect, egt, eot, koeo, koer, and tcm codes, i get mixed up! I edited it and fixed it! Thank you!
Old Mar 21, 2011 | 08:11 PM
2006powerstroke90
Well I have a 36mm socket for my filters.
Will that work? I don't want to have to cut a slot in it.
Might just go buy a wrench tomorrow just to be Safe.
So I just take it out clean it up a litte bit and all should be well and I can rule that out?
Old Mar 21, 2011 | 08:12 PM
npccpartsman
Well.......ICP IS a sensor--injection control pressure sensor
IPR is really an electrically controlled relief valve--Injection Pressure Regulator. If the IPR sticks or defaults (trash or no electricity) open all the HPO is dumped to sump and a no start condition results.
Yes, I'm still dealing with all the nomenclature. I thought I was uptown when I got my 93 chevy in 99 and had to worry about EPROM's and knock sensors. I'm used to carb floats, points and condensors, and "TWIST IT LEFT FOR A LITTLE MORE TIME" as go fast parts.
Old Mar 21, 2011 | 08:14 PM
00buck75's Avatar
00buck75
Would bad IPR cause a rough idle after cold start?
Old Mar 21, 2011 | 08:15 PM
npccpartsman
See how it starts in the morning first. It may never give you another minutes trouble. A wrench won't work without removing the turbo....you need a socket with a slot because of the electrical connector on the IPR.
Old Mar 21, 2011 | 08:16 PM
2006lariat's Avatar
2006lariat
Damn It! Your killin me here! LOL Back on subject! lol
2006powerstroke90
Haha
  #28
npccpartsman
Probably not. that's likely to be injector stiction.
Old Mar 21, 2011 | 08:18 PM
  #29
2006powerstroke90
Is the downhill side a good thing or a bad thing? Lol
Old Mar 21, 2011 | 08:22 PM
  #30
2006lariat's Avatar
2006lariat
Downhill side is good!
