Help
Old Mar 15, 2011 | 09:43 PM
Ford67's Avatar
Ford67
Help
well first why is there 2 fuel filters 2 mine has 1 missing the one next to the oil filter and the plastic thing inside it that the filter sits on is broken will it hurt it to run it and were do you get a new water seperater or whatever that thing is that goes into the actual housing
Old Mar 15, 2011 | 09:52 PM
BLADE35's Avatar
BLADE35
the one that is broke is the small one on top? the water separater is the lower one on the frame
put the filter in first then tighten the cap. I know they say snap it into the cap then tighten but that didnt feel right.
those guts to that filter will probably be a dealer item only
Old Mar 15, 2011 | 09:57 PM
bismic's Avatar
bismic
The most efficient way to remove water, large particulates, and small particulates is with two filters. It will also offer protection if the primary filter fails in any way. It is done to protect the injectors. If you run your truck w/ only the primary filter you will vastly increase the chance of ruining injectors.
Old Mar 15, 2011 | 10:00 PM
Ford67's Avatar
Ford67
ya the internals in the housing broke with the torx bits ik its replacible but i cant find it. if i place the filter in without that its doing nothing correct??? or will it still help
Old Mar 15, 2011 | 10:08 PM
rocky1074's Avatar
rocky1074
You lost me....Can you clarify what is broken??? I would not run truck with only one filter as bismic stated!!!!
Old Mar 15, 2011 | 10:12 PM
Ford67's Avatar
Ford67
the fuel filter housing on top of the engine the little plastic piece inside that the filter sits on
Old Mar 15, 2011 | 10:15 PM
m-chan68's Avatar
m-chan68
Ford67 is referring to the secondary fuel filter standpipe inside the housing, by the sounds of things. And yes, you can add me to the list to advise you not to drive (or even so much as run the engine for another minute) before getting this fixed.
Old Mar 15, 2011 | 10:25 PM
Ford67's Avatar
Ford67
is it called a standpipe cause i want to no wht i need . i just no it comes out with 2 or 3 torx bits
Old Mar 15, 2011 | 10:28 PM
Ford67's Avatar
Ford67
if anyone knows what its called let me no so ik what to order ik what it looks like and cant find it anywhere
Old Mar 16, 2011 | 06:03 AM
npccpartsman's Avatar
npccpartsman
Navistar calls it a Clean Fuel Return Tube Part # 1843061C92
Ford part # 3C3Z 9T289 AA
Wow.....MSRP from Ford is now $40. Used to be <$10 IIRC
Old Mar 16, 2011 | 11:40 AM
rocky1074's Avatar
rocky1074
parts guy ed has it for 29.10 plus shipping of course
3C3Z9T289AA
KIT TUB FU/FLTR RTN
www.partsguyed.com
Fett Affen
Aug 29, 2011 04:53 AM
allisonmo2
Feb 23, 2009 06:22 AM
Headviking
Jan 28, 2008 07:05 PM
tndiesel
19
Oct 31, 2007 04:00 PM
wildcard30
Oil & Lubrication
24
May 10, 2004 11:30 PM
