small filter
Old Aug 28, 2011 | 10:54 PM
Fett Affen's Avatar
Fett Affen
small filter
I have a 2004 6.0 and I replaced the fuel pump with an airdog, no problem with the spin on filter, however, looking for just the small filter is proving to be extremely difficult. I have called a number of the filter companies directly and they all tell me the same thing, "It is sold as a kit". Does anyone have any suggestions. Someone has to make this filter and it seems like most manufacturers are re-boxing the filters, racor was no help as most of the blogs state that racor makes the motorcraft. I hate to buy a $50.00 filter and throw away the large filter. The airdog spin-on is a 2 micron so in theory you could do away with the small filter but I like two levels of defense in the fuel system.
Old Aug 28, 2011 | 11:33 PM
Cowboy65's Avatar
Cowboy65
I've only seen the fuel filters for sale as a kit. I would suggest checking with Racor (which it seems you have already done), International, and Diesel Filters Online. If you strike out on all three my bet is that you can't buy just the small filter.
Old Aug 29, 2011 | 04:42 AM
npccpartsman's Avatar
npccpartsman
You can't buy just the small filter......believe me I've tried. I've been running without the small filter for about 4 years now with no problems. If you remove the small filter you have to remove the stand pipe that it fits on also. The AD does a very good job at filtering IMHO. If you just have to have the small filter then you'll have to buy the kit but it should be good for a VERY long time.
Old Aug 29, 2011 | 04:53 AM
ford390gashog's Avatar
ford390gashog
No real need for the small filter! Just use the AD and sleep well at night!!
mrjc
6.7L Power Stroke Diesel
31
May 15, 2021 03:16 PM
davidwjacob
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Oct 24, 2014 08:02 PM
whporwil
6.4L Power Stroke Diesel
Aug 12, 2010 06:46 AM
tow2atm
Nov 5, 2007 12:11 PM
Beachbumcook
Apr 2, 2006 01:58 PM
