Lucas Injector Cleaner
Old Mar 14, 2011 | 03:16 PM
Qwatali Hunter's Avatar
Qwatali Hunter
Does anyone have any history with Lucas Injector Cleaner? What is the best fuel additive for a 2003 6.0L? I just had to replace all the injectors and don't want to have that problem again.
Old Mar 14, 2011 | 03:26 PM
hubler13f's Avatar
hubler13f
This is one of those subjects that some guys go crazy on. I haven't had any experience with Lucas myself but alot of guys run Diesel Service, others run 2 stroke oil, others refuse to run anything at all with no problems. There are plenty of threads that have beat this subject to death.
Old Mar 14, 2011 | 03:31 PM
scrdanis's Avatar
scrdanis
I use Diesel Kleen. you get it at Wal-mart. They have a white bottle I use in the winter (Has an anti-gel in it) and ht egrey in the summer months. Not sure of your location, you may stay with the grey one.
Old Mar 14, 2011 | 04:26 PM
smokersteve's Avatar
smokersteve
I have used it with out issues. But my fuel system was never in a state that needed an additive when I used it. Same with when I use Diesel kleen or TC-w3, never notice unless I am having an issue and so far I have not because I use DK and TC-w3 here and there.
The lucas additive is more for gas engines. It does more good with them then it does for diesel. I don't know anything bad about it.
Old Mar 14, 2011 | 05:32 PM
69cj's Avatar
69cj
Diesel kleen, or Ford PM-23 or Stanadyne are all good in the fuel. You are looking for cetane boost and lubrication. Not cleaning. If the fuel press. at thousands of psi can't keep the injector clean some chemical won't. Regular oil changes and oem filters also help the injectors since the oil drives the injectors. 5,000 mile oil change intervals.
Old Mar 14, 2011 | 07:12 PM
BobsF350's Avatar
BobsF350
ive ran Lucas forever.03 175k all stock original injectors
it is starting to suffer some stiction gonna try revx
Old Mar 14, 2011 | 07:36 PM
amadas350's Avatar
amadas350
you can get a 80oz grey bottle of the diesel kleen at tractor supply for $12 and will do 250 gal..
Old Mar 14, 2011 | 09:38 PM
smokersteve
Cleaning is more for the parts before the inj tip.
traxx808
17
Aug 27, 2014 02:11 PM
Electricowboy
Jun 28, 2014 08:49 AM
mrsvegan
52
Nov 2, 2013 10:33 AM
zamunda
1997 - 2003 F150
16
Feb 3, 2010 09:21 PM
Oversize
Apr 19, 2009 11:26 AM
