04 Acceleration problems
Old Mar 14, 2011 | 08:59 AM
WestonGray's Avatar
WestonGray
I have a 2004 250 with 153,000 miles. It sat for about a month or so, and when I fired it up recently after putting new batteries on, it won't accelerate as strongly as it used to. It seems like the turbo air isn't getting into the engine. I can hear it spinning up really strongly, but it's not helping the engine it seems like. It can get up to highway speeds, but its almost like it's acting like a naturally aspirated engine. Thoughts?
Old Mar 14, 2011 | 09:28 AM
embry1123's Avatar
embry1123
Check the BLUE boot on the turbo outlet side. If it is cracked or as sometimes happens, blown off, it will do exactly that.
Old Mar 14, 2011 | 12:22 PM
zhilton's Avatar
zhilton
And if everything is well after checking ALL of the boots from the turbo...to the inter-cooler and back to the intake; you may have stuck vanes on the turbo.
Old Mar 14, 2011 | 02:10 PM
steelhead2's Avatar
steelhead2
id do like the previous 2 posts say, then i would pull the air cleaner and check it.youd be surprised what will decide to take up residence in there after a prolonged sit.also try the vgt re-learn strategy in the tech folder.
Old Mar 14, 2011 | 02:17 PM
WestonGray's Avatar
WestonGray
Found a 1in tear in the boot. Is this big enough to cause the problem? Also, can I replace this with some basic hose from auto zone or is the factory ford part with the clamp stapled to it absolutely essential?
Old Mar 14, 2011 | 02:20 PM
steelhead2's Avatar
steelhead2
yes,that will definitely cause your problem,and absolutely not,replace the hose with either an original,or you can get them aftermarket.
Old Mar 14, 2011 | 02:27 PM
embry1123's Avatar
embry1123
which boot?
Old Mar 14, 2011 | 02:37 PM
wulfman's Avatar
wulfman
try rif raff diesel best price for boots
Old Mar 14, 2011 | 10:10 PM
WestonGray's Avatar
WestonGray
Went to the dealership and got the boot for $70. Problem solved! Thanks guys
Cowcharge
Jun 29, 2012 09:32 PM
Stephanie Korhel
81
Jan 20, 2012 08:22 PM
vze2sgxa
Jan 24, 2006 08:57 PM
vze2sgxa
Jan 19, 2006 06:24 PM
kmans777
1983 - 2012 Ranger & B-Series
Dec 8, 2005 07:20 PM
