Tekonsha Prodigy, P2 or P3 are very good controllers. I have used a Prodigy and a P3. They are easy to install, easy to use and very reliable. You can get a wiring harness that is pre-made to plug directly into the controller and the truck.
I have a 2006 f350 and i thought they come from factory with a brake controler right in the dash. I may be wrong but all the 250 350 s I looked at in the later 6.0l models did. Or is this just an option?
Integrated TBC is an option across the line from 2005+.
To the OP: I would look at the Tekonsha P3. I have one and it does an excellent job.
