factory brake controller
Old Jul 25, 2010 | 04:38 PM
fordxl68's Avatar
fordxl68
Are the factory brake controllers for a 2009 and a 2010 the same. I have a chance to but on locally for $200. I was told that 09 and 10 controllers are not interchangeable the. the add says 2009/2010 F150 factory brake controller
Old Jul 25, 2010 | 08:47 PM
xciton's Avatar
xciton
If I'm not mistaken, the 2009 model had a built in display, where as the 2010 model has removed the built in display and the information is now shown in the odometer area.
Old Jul 28, 2010 | 06:37 PM
ohboy44's Avatar
ohboy44
This is correct.
Old Jul 31, 2010 | 01:09 PM
big_saxy's Avatar
big_saxy
how can you add the brake controler if your truck did not come with one?
Old Jul 31, 2010 | 01:27 PM
big_saxy's Avatar
big_saxy
my widow sticker says trailer sway control under functional and 3.55ls axle 7200#gvwr package under the optional equipment. how set is this truck for towing around 8k? is there anything i should add?
Old Aug 1, 2010 | 09:06 AM
fordxl68's Avatar
fordxl68
just installed and had it turned on
I bought a used factory brake controller on ebay for $150. I called a Ford service dept. to have it turned on. They weren't sure how to do it ,so I printed off the instructions that were on this forum for them. they used the instructions and still charged me 1 hour labor.I'll never go there again. They said the min. they charge is a hour labor.But thanks for the instructions on how to do it so they know in the future. BTW it it worth the money for the controller and the activation. I used it to tow my 9600lb. fifthwheel. It works allot better that any aftermarket one.
Old Aug 1, 2010 | 09:16 AM
Deluxe05's Avatar
Deluxe05
Download Ford's Towing Guide for your truck here: ProFleetSales.com - Ford Official Towing Guides
Between this & the sticker(s) in your driver's side door, you should be able to accurately determine what your truck is rated to tow.
Do you have the tow package or any other package that includes a transmission cooler? If not, that would be a point of some concern.
Old Aug 1, 2010 | 11:50 AM
big_saxy's Avatar
big_saxy
truck does have the class 5 hitch and 7 pin round from the factory as well as a trans cooler.
duckhunter 51
2009 - 2014 F150
19
Jun 20, 2012 11:56 PM
2jhanna
Oct 11, 2010 02:02 PM
brian97cobra
2009 - 2014 F150
Aug 31, 2010 07:14 PM
calidogj14
2009 - 2014 F150
Mar 13, 2010 06:42 AM
lowezz
2009 - 2014 F150
May 5, 2009 09:04 AM
