Slight miss
Old Mar 12, 2011 | 08:00 PM
swcscb's Avatar
swcscb
Slight miss
Have an 03 F250 with 6.0, approx 110K miles and always maintained by dealer. Lately I have noticed a slight miss or hesitation when going up a slight grade in high gear. This only occurs before the truck warms up completely and I can mash the gas until it down shifts and it will accelerate smoothly with no hesitation. Could this be an indication of weakening injectors, fuel pump, or ???. Any ideas on what to look for would be appreciated. Bill
Old Mar 12, 2011 | 08:28 PM
bismic's Avatar
bismic
Hard to say - there are a number of things that can cause a hesitation - turbo, ICP, injectors, FICM, low fuel pressure .....
What is your oil and fuel maintenance program (fluid and filters)?
Any codes?
Any mods?
Any major repairs in the past?
Old Mar 13, 2011 | 03:31 PM
swcscb's Avatar
swcscb
03 slight miss
No codes, no mods, zero repairs, maint by the book by dealer since new. The only thing I have ever done myself was to add a Lucas fuel treatment every other fillup, and add cetane boost & anti gel in the winter.
Thanks, Bill
Old Mar 13, 2011 | 08:15 PM
bismic's Avatar
bismic
I would invest in a good set of gauges or an AutoEnginuity. Without more information, it is impossble to pinpoint your issue IMO.
There are cheap things to try - like pulling and cleaning the EGR valve (maybe even consider replacing it), cleaning the MAP sensor hose and EBP tube, cleaning the turbo, inspecting the ICP connector for oil soaked condition, check FICM voltage, check battery health (with a real load tester, not just a hand-held unit). You might get lucky and it is one of these possibilities.
Old Mar 14, 2011 | 06:23 PM
swcscb's Avatar
swcscb
Thanks Mark, appreciate the info. Just replaced both batteries so thats one less thing to worry about. Bill
Old Mar 14, 2011 | 07:22 PM
bismic's Avatar
bismic
What code reader did you use?
Mike450
19
Jan 21, 2013 02:35 PM
Joe28443
Apr 22, 2012 11:56 AM
BigJake34452
21
Nov 13, 2008 08:32 PM
old uhaul
May 23, 2005 08:14 AM
gsc1996
18
Jun 23, 2002 03:59 AM
