Odd noise
Old Mar 14, 2011 | 05:04 PM
specialK4464's Avatar
specialK4464
Odd noise
Ok, so today i just noticed an odd noise under my hood after i shut my truck off. I drove it maybe 25 miles, so it was warm, but when i parked it i decided to lift the hood for the heck of it. I noticed that it sounded like stuff was boiling. Ive never heard of something boiling after driving your vehicle so i thought id check to see what you guys had to say about it. any advice it helpful. thanks!
Old Mar 14, 2011 | 05:18 PM
utjer's Avatar
utjer
Is your coolant level going down?
Old Mar 14, 2011 | 07:45 PM
bismic's Avatar
bismic
I would quickly find a way to see the REAL coolant and oil temps. A scangaugeII or an Edge Insight are perhaps the cheapest way to go about this.
Old Mar 14, 2011 | 08:53 PM
dchamberlain's Avatar
dchamberlain
You may be describing refrigerant from the A/C high pressure side bleeding through the orifice into the low pressure side, where it boils into a gas. That could be described as a boiling sound.
Try driving the truck for awhile with the heater control in the OFF, VENT or FLOOR positions (the only positions where the A/C compressor doesn't run) and see if it still does that.
