Coolant Flush
Old Mar 12, 2011 | 03:19 PM
Shaneb75's Avatar
Shaneb75
Strokin Okie
Coolant Flush
Not new to the Forum, but new to the Powerstroke team....
Just purchased and 06 F250 Crew Back FX4 with 96,000 miles. I am in the process of making sure all the maintenance is caught up.
Thanks to you and your detailed threads on this forum, I successfully, and I believe correctly flushed my coolant, and installed a Sinister coolant filter!!
I should be able to budget the Semi Bulletproof package in July, as maintenance and not to fix a problem!! The truck seems to be in great shape!
So Far I have change-
Air Filter
Fuel Filters
External Trans Filter
Flushed Brake System - Mighty VAC
New Ford EGR Valve - and no signs of moisture!!
Old Mar 12, 2011 | 06:07 PM
69cj's Avatar
69cj
Didn't see oil and oil filter listed and you might also want to install a Magnefine R038M 3/8" filter in your power steering return line. On your oil, fuel, tranny and air filters be sure to use OEM filters only.
Old Mar 14, 2011 | 05:57 PM
Shaneb75's Avatar
Shaneb75
Strokin Okie
The dealership changed it before I bought it, so I am good for a while and plan to use the Motorcraft filter. The only one I purchased that is not OEM is the internal trans filter, its a WIX... Should I give it away or use it?
Thanks for the heads up on the power steering filter!
Old Mar 14, 2011 | 07:12 PM
00buck75's Avatar
00buck75
69cj,
Why oem filters?
Don't know about fuel filters but my local walmart has motorcraft & fram oil filters.
I was always buying the motocraft filter till one day while standing in the isle, I opened the fram & motorcraft boxes and compared filters. they were 100 % identical right down to the stenciled ink numbers on the top of the filter. The only difference was fram was a few bucks cheaper. Fram make the motorcraft filters??
Old Mar 14, 2011 | 07:15 PM
69cj's Avatar
69cj
You really don't need to change the internal filter unless doing a rebuild. See if you can return it for your money.
Magnolia Tom
Feb 6, 2013 05:37 PM
amd_038
Aug 20, 2011 08:03 PM
Liquid10Rider
Apr 25, 2011 03:00 PM
lakewood
Feb 11, 2010 10:45 PM
bismic
Aug 18, 2009 12:03 PM
