Over Drive Light and Shifting
Old Mar 9, 2011 | 11:08 PM
rucco111's Avatar
rucco111
Unhappy Over Drive Light and Shifting
I just bought a 2000 Excursion V10 with 220,000 miles LOVE IT. It has been taken care of and everything but (of course there is a but...) the transmission does not like being in over drive. It seems to 'buck' not slip when under any load in over drive. I can accelarate and have it down shift with no porblems then it is fine.
Also the over drive light on the shifter will not come on. I pulled the button and put a tester to shifter but no power was going to it. (I had the motor on in park with the passenger door open.)
Could these be related?
Please HELP!
Old Mar 10, 2011 | 01:45 AM
TYZ78F150's Avatar
TYZ78F150
A good place to start would to check the wiring going to the shifter. A very common problem is nicked/frayed wiring, especially where the wire comes in contact with the metal of the shifter. Remove your steering column covers and check it there. Look it up on here and there are numerous threads with pics. As for the bucking when in overdrive, mine was doing it when I had a bad COP. Good luck!!
Old Mar 10, 2011 | 07:02 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Bucking in overdrive is almost always an engine miss.
Old Mar 10, 2011 | 10:06 AM
rucco111's Avatar
rucco111
Awsome...I will be looking at those tonight. I was getting a mis-fire in #2 so I will start with that one. i found a great write up on how to check the COP. Also I will be pulling the cover off the column and looking for frayed wires.
I know we just met but I lvoe you guys!!! (Hopefully :P)
thanks
Old Mar 10, 2011 | 10:57 AM
Eric H's Avatar
Eric H
thanks
Do you have a link to the COP testing write up? This is on my to-do list as well.
Thanks!
Old Mar 10, 2011 | 11:01 AM
rucco111's Avatar
rucco111
Here is what I found.
https://www.ford-trucks.com/forums/9...-problems.html
Old Mar 10, 2011 | 11:05 AM
Eric H's Avatar
Eric H
Thank you!
Old Mar 10, 2011 | 01:14 PM
TYZ78F150's Avatar
TYZ78F150
At that kind of mileage, it is almost certanly a bad COP. I would change all plugs at the same time.
Old Mar 10, 2011 | 02:50 PM
UrbanXX's Avatar
UrbanXX
What you have is a spark plug mis-fire. If you replace the plugs and the plug boots you will solve the problem more than likely. Do this first! You are looking at about 90.00 in parts. Now if thats not the problem it leaves the COP. But, more than likely its not a COP.
Old Mar 10, 2011 | 07:14 PM
LivingLarge's Avatar
LivingLarge
I had this issue about 100,000 miles ago. In my case it was dirty injectors.
I had injectors cleaned, replaced fuel filter and the bucking in overdrive was gone.
RustyFord88
Feb 5, 2023 11:09 PM
ebaldwin89
17
Feb 27, 2018 12:22 PM
curtainrod
Jul 29, 2015 05:54 AM
jakeymon
Dec 13, 2014 03:49 PM
brainwashed
19
Oct 4, 2011 05:46 PM
