4 WHEEL DRIVE
Old Mar 9, 2011 | 02:18 PM
QUIGLEY96's Avatar
QUIGLEY96
4 WHEEL DRIVE
Hello, I am new to this site but have a friend that has found it to be a huge help for him. I have a 99 F-350 Powerstroke and I lost the ability to use my 4 wheel drive. I replaced the switch in the dash ansd that did not help. My engaged light does not come on in the dash so I am wondering if there is a relay or fuse that runs this. Any help on this matter would be greatly appreciated.
Old Mar 9, 2011 | 02:37 PM
clintbonnie's Avatar
clintbonnie
Check the #17 fuse under the hood fuse box..it is the 3rd one down on left from top..
Do you have owern's guide for your PSD.. if not, i have link to Ford to download one..
And a Big Welcome to the Forum..
Old Mar 9, 2011 | 02:52 PM
clintbonnie
Here is Ford's link to download a owner's manual for your psd..
Ford, Lincoln & Mercury Service Coupons | Save Money on Your Next Service Appointment | FLMowner.com (click on Vehicle Basic... then ower's manual)
Old Mar 9, 2011 | 03:06 PM
QUIGLEY96's Avatar
QUIGLEY96
Thank You Clint. I do not have a owners manual.
Old Mar 9, 2011 | 03:31 PM
Brother Les's Avatar
Brother Les
If the fuse is blown or the seals are not holding and do not allow the vacuem to work, you should still be able to ingauge them by hand on the hubs. Why did you think that it was the 'switch' that was bad?
Welcome to FTE
Old Mar 9, 2011 | 03:39 PM
QUIGLEY96's Avatar
QUIGLEY96
WELL...NO LUCK WITH IT JUST BEING A BLOWN FUSE. ANY OTHER IDEAS OR SUGGESTIONS?? ANYTHING AND EVERYTHING IS GREATLY APPRECIATED!
Old Mar 9, 2011 | 03:45 PM
makomaker's Avatar
makomaker
Welcome to FTE
what he said
Old Mar 9, 2011 | 04:41 PM
bdrummonds's Avatar
bdrummonds
by any chance does your air conditioner blow out of the defrost vents? If so, then you are looking for a vacuum leak. If the light is not coming on on the dash then you may need to crawl up under truck and make sure the wiring pigtail has not worked loose from the transfer case.
Old Mar 10, 2011 | 09:50 AM
QUIGLEY96's Avatar
QUIGLEY96
MY VACUUM PUMP IS WORKING. I DO REALIZE THAT IF THE VACUUM PUMP IS LEAKING THE AUTO HUBS WONT WORK BUT I CAN PUT THEM IN MANUALY BUT THAT IS NOT THE ISSUE. THE SWITCH ON MY DASH WILL NOT ENGAGE MY 4 WHEEL DRIVE OR TURN ON THE 4WD LIGHT IN THE DASH. THE WIRING PIGTAIL IS PROPERLY CONNECTED. IS THERE A WAY TO TEST THE 4WD SHIFT MOTOR? I CHANGED THE DASH SWITCH KNOWING THAT IT IS NOT UNCOMMON FOR THEM TO FAIL. THANK YOU FOR ALL OF THE SUGGESTIONS.
Old Mar 10, 2011 | 10:03 AM
PaysonPSD's Avatar
PaysonPSD
There are 2 relays under hood for ESOF. One is for shifting from Hi to Low and the other from Low to Hi. You should be able to hear or feel one of them operate when you turn the switch.
This is the contact arrangement for these relays. Bench test them so you can rule them in or out as your problem.
dship
1997 - 2003 F150
Aug 29, 2005 09:32 PM
bmp887
1983 - 2012 Ranger & B-Series
Jan 5, 2005 09:36 AM
BigB4000
Offroad & 4x4
May 1, 2003 11:51 PM
jfj
Aug 28, 2002 01:52 PM
