Transmission problems in Reverse
Old Mar 8, 2011 | 06:48 PM
firefighter15's Avatar
firefighter15
Im hoping someone may be able to give me some insight as to why when after ive been driving my truck which is an automatic after a while and the transmission is warm it almost stalls the engine when I put it in reverse. It runs fine through all the other gears and is only a warm transmission in reverse when it acts up.
Old Mar 8, 2011 | 07:06 PM
Night Crawler's Avatar
Night Crawler
sounds like the T/C is locking up, why I don't know
Old Mar 8, 2011 | 07:58 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It can lock when it shouldn't for several reasons.
Low trans fluid
Loose/missing internal filter
Leaking seals
Worn pump
TCC solenoid/wiring problem
Bad torque converter
I listed those from most likely to least likely.
RNH524
Apr 1, 2012 12:45 PM
duramaxthis
Escape & Escape Hybrid
Feb 9, 2012 07:51 AM
Justin's Green Truck
1997 - 2003 F150
Nov 28, 2010 07:27 AM
highlandescape
Mar 3, 2007 09:27 PM
ninetythreef150
Jan 10, 2007 11:10 AM
