Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
transmission question
Old Feb 23, 2007 | 11:15 PM
highlandescape's Avatar
highlandescape
02 escape xlt fwd
after the engine and transmission are warmed to operating temp, when put in reverse, it takes a few seconds to kick in. then when its given gas, it still kind of jerks and shimmys. transmission fluid clean and proper level. tranny service not more than a year ago(approx 10,000 miles). never been abused.
what would cause this?
Old Feb 24, 2007 | 10:39 AM
sfcwoodret's Avatar
sfcwoodret
It may be a belt slipping in the tranny from being loose or worn out. It happens, and a shop will replace them or reset it.
Old Feb 25, 2007 | 07:00 PM
highlandescape
thanks for the advice. i will bring it up next time its in the shop.
Old Mar 3, 2007 | 07:20 PM
JFUSION's Avatar
JFUSION
I've had that happen with other vehicles when the fluid level wasn't right, the fluid level is tricky to check sometimes as the fluid has to be fully warmed to get an accurate reading (30+miles of driving). Mine was actually overfilled last time the dealer changed my tranny fluid , it read okay when cold but as soon as it heated up it read much higher (too high). If a dealer tech can misread the fluid level it could happen to anyone IMO. Checking it fully hot and after running it through all of the gears gets you the most accurate reading. Double check yours , otherwise it is likely a mechanical issue. Changing the fluid if it has a few miles on it is worth a shot too, despite being clean, approaching 30,000 miles is worth changing.
Old Mar 3, 2007 | 08:25 PM
stuart1's Avatar
stuart1
Transmissions don't have belts.
Old Mar 3, 2007 | 09:09 PM
5_labsownus's Avatar
5_labsownus
A bad buckle on the belt? LOL
Old Mar 3, 2007 | 09:27 PM
sfcwoodret's Avatar
sfcwoodret
My bad, how about a band!
ztcarver83
Sep 19, 2013 08:42 PM
CM1
Jul 27, 2008 09:55 PM
1975Ford
Nov 11, 2005 01:05 AM
topher
Mar 30, 2002 01:23 PM
Ratsmoker
Oct 16, 2001 09:55 PM
