quick question
Old Mar 4, 2011 | 04:53 PM
brownie83's Avatar
brownie83
Question quick question
hey guys..
installing a new ebp sensor and tube tomorrow. can i remove the bracket to clean it out thoroughly? i didnt want to lose all the hpop oil. i know ill need to rtv it, but just dont want to make a huge mess with the oil. thanks alot...
chris
Old Mar 4, 2011 | 04:57 PM
Farmboypowerstroke's Avatar
Farmboypowerstroke
Originally Posted by brownie83
hey guys..
chris
Just unscrew the tube from the bracket, clean it( or put a new tube on), screw it back on.
Old Mar 4, 2011 | 05:05 PM
clintbonnie's Avatar
clintbonnie
There is no oil here...if you talking about the bracket that holds the sensor in place..
Old Mar 4, 2011 | 05:29 PM
brownie83's Avatar
brownie83
why is there rtv there to seal? or is it not needed?
thanks for the fast reply...i know some say they clean the hole in the bracket...just thought it would be easier with it out of the truck....
thanks again
Old Mar 4, 2011 | 05:45 PM
clintbonnie
thanks again
The other of the tube screws into the front side of the passenger exhaust manifold.. sometimes this fitting is rusted.. you might want to spray some FreeAll or penetrating oil here a couple of hours before you remove the tube. It just pressure from the exhaust the sensor is measuring.. no oil involved..
Old Mar 4, 2011 | 05:48 PM
brownie83's Avatar
brownie83
no not the tube...the actual bracket. the one that the sensor and the tube attach to. there are 2 bolts that hold the bracket to the hpop resivour. the tube is off and the sensor is out...just want to clean the hole in the bracket for the sensor and tube to flow freely...any ideas on this?
Old Mar 4, 2011 | 06:05 PM
clintbonnie
You really don't have to remove the bracket to clean it.. I would not think the bolts would go into the oil reservior..
Old Mar 4, 2011 | 06:10 PM
brownie83's Avatar
brownie83
i was just hoping to get the hole in the bracket cleaned up spotless before installing a brand new tube and sensor...ill try with out removing, i dont want to lose all the oil in my hpop
Old Mar 4, 2011 | 07:10 PM
Farmboypowerstroke
If you want to pull the bracket off, pull it off. You won't lose your oil in the HPOP
ColeT24
Feb 16, 2015 09:11 AM
mbenedict
Oct 26, 2007 08:25 PM
ford390gashog
Oil & Lubrication
Feb 8, 2005 06:05 AM
ford390gashog
Oil & Lubrication
Jul 4, 2004 02:44 PM
Scouter
May 10, 2004 10:59 AM
