Transmission Oil Temp
Old May 7, 2004 | 01:41 PM
Scouter's Avatar
Scouter
Exclamation Transmission Oil Temp
Hey All!!
I just bought a temp gauge for my transmission oil. In the instructions, it tells me to place the sensor on the oil return to the transmission. I would think that I would want to see how hot the oil is coming out of the transmission.... Thoughts?????
Old May 7, 2004 | 11:16 PM
Spectramac's Avatar
Spectramac
It will just scare you on the outgoing side. You just want to know how hot it is after the coolers.
Old May 8, 2004 | 09:25 PM
Birken Vogt's Avatar
Birken Vogt
The oil return doesn't really tell you much, with a completely plugged cooler the return line will still say just ducky...you need to put it in the hot line but be prepared to see high temperatures, or put it in the pan oil (best). I understand both the C6 and the E4OD have a great port on the side that is mainline pressure and gives a good indication of actual pan oil.
Birken
Old May 10, 2004 | 09:06 AM
Scouter's Avatar
Scouter
Thanks guys!
I placed it on the oil outlet line and have tested it. I drove for 20 minutes on the hyway and the temp just came up to 100F! I guess the real test is when I am hauling!
Old May 10, 2004 | 10:22 AM
Spectramac's Avatar
Spectramac
I guess I left that one hanging huh! I've always put them in the pan.
Old May 10, 2004 | 10:36 AM
shorebird's Avatar
shorebird
I did mine this way;
Old May 10, 2004 | 10:40 AM
Scouter's Avatar
Scouter
Thumbs up
Thanks for the picture! Makes it so much easier! I am thinking of changing location after seeing the picture..... what size is the sensor & hole???? What temps are you seeing (both hauling and normal)?
Old May 10, 2004 | 10:59 AM
shorebird's Avatar
shorebird
The sensor is the one that came with my Autometer guage. it fit into the inspection port on the 4R100 trany in my E-350. I'm not sure about the size off the top of my head. But I will check the size of the plug that came out and post it later. When towing my highest temp has been 190 degrees.
cutlass
85
Oct 13, 2020 01:54 PM
northwindone
Modular V10 (6.8l)
Jul 21, 2017 03:09 PM
Otto396
28
May 3, 2016 09:41 AM
gdiehl
6.7L Power Stroke Diesel
Mar 31, 2016 03:48 PM
czthda
Jun 26, 2013 04:01 PM
