Carb help...
Old Mar 20, 2003 | 05:15 AM
macguyver's Avatar
macguyver
Carb help...
Set the timing first or you'll be chasing your tail.
Old Mar 22, 2003 | 04:22 PM
Racerdave's Avatar
Racerdave
Carb help...
ok, I lined the rotor up with the mark on my distributor (#1). and looked at the timing marks and it says 20deg towards BTC, I marked TDC with chalk and loosend my dizzy and started her up and put the timing light on it and the mark was way off, so I started turning, and she started running better, and then clunk..... I couldnt move her any more because the radiator hose is in the way!, I was wondering if I can take the dizzy out and move it back 1 tooth on the gear so I can get the timing light to line up with TDC? Can I do this and see if it works or will it screw somthing up? I know that the timing had been off since I bought the truck but I didnt think it was off that much. The PO had to take out the Dizzy because he did a rebuild on the engine... What can I do to solve my problem?
Old Mar 22, 2003 | 04:42 PM
Torque1st's Avatar
Torque1st
Posting Legend
Carb help...
First off, read the book on how to set the timing on your engine. There is a specific proceedure, ususally with pictures, that calls for certain vacuum lines to be plugged etc. The book would have shown you exactly where the timing marks were also.
Old Mar 22, 2003 | 07:48 PM
macguyver's Avatar
macguyver
Carb help...
Or you could read this thread. It should have a lot of info.
https://www.ford-trucks.com/forums/s...hreadid=102578
Old Mar 22, 2003 | 08:42 PM
Racerdave's Avatar
Racerdave
Carb help...
I read the book (and just bought the chilton CD) great tool to learn on! I recomend it to everyone! It has one picture of the harmonic balancer, I was looking on the drivers side for it, I thouhgt for some reason it was under the water pump? I found it under the alternator, and the only line that I gata plug is the vacuum advance, I know how to se the timing with a light, it just wont move any further, I think that it may be 1 tooth off on the distributor gear and was wondering if it were possible to move it one tooth back on the dizzy? Or if it will mess up somthing? Maybe mess up my ignition? I am not sure thats why im asking? as for now, it runs ok but seems like the timing is off just a tad bit because it missfires under certian RMP's
Old Mar 22, 2003 | 09:33 PM
macguyver's Avatar
macguyver
Carb help...
just lift the distributor enough to move it one tooth.
The opposite way you are trying to move the distributor.
Old Mar 24, 2003 | 03:05 PM
Racerdave's Avatar
Racerdave
Carb help...
its not going to mess anything up?
Old Mar 24, 2003 | 03:13 PM
macguyver's Avatar
macguyver
Carb help...
Normally, no.
Racerdave
Jan 20, 2011 05:03 PM
cdawley4
Mar 30, 2010 07:24 PM
Cybertaz126
19
Nov 16, 2005 08:16 PM
Racerdave
21
May 21, 2003 03:34 PM
Racerdave
Mar 15, 2003 07:18 PM
