Phaser Tick Fix without replacing Phasers.
Old Aug 16, 2017 | 11:23 AM
  #76
gjepsen's Avatar
gjepsen
6th Gear
Originally Posted by roboink555
Did you get the code cleared after or not...
Side note, if the VCT are seized, the system will not return to normal but stay advanced.
Old Aug 17, 2017 | 02:41 AM
  #77
redfishtd's Avatar
redfishtd
Very old thread
Changing VCTS is always a good thing . The newer ones 07 08 's have to pull valve cover . They do varnish up and screens get plugged . It won't fix broken guides or blown tensioner gaskets . Same with roller and lash adjuster problems . During timing job these can be reused ,cleaned if necessary.
But if you shock this system doing an engine flush be prepared to do a timing job very quickly . Running some marvel m oil is a gentler approach . A lot of us run it all the time after engine job . Keep her clean .
Old Apr 1, 2019 | 04:47 AM
  #78
Mytruckblows's Avatar
Mytruckblows
05 f150 issues
To all in this forum ,theres alot of try this try that.i personally spent alot of cash on doing thd whole job oil pump,timing ,phasers,vct,cam sensors ,plugs,wires,spark plugs ,coil packs.my trucks been in the garage for 2 yrsnow cause the problem is still there ,it starts fine but after warm up it goes into where it wants to die at idle if i hold rpms at about 1200 its fine.with that being said does anyone have the answer 104k on my motor i changed oil at about 5k myself every time.my biggest curiosity is will a high velosity oil pump do the trick thanks
Old Apr 1, 2019 | 10:17 AM
  #79
redfishtd's Avatar
redfishtd
Dying like that doesn't seem to be timing parts related
Of course we would like more info from like tprque pro . Mode six under test results to see if misfire count starting to build up on any cyl .
Cleaning maf,thottle body is aways good .
But your symtoms are common to a vacuum leak , a homemade youtube smoke machine is a great way to find it . It can be all the way back to the gas tank and parts on rear axle /Of course you should check out your FPDM on rear axle . It will fail sooner or later .
Start a new thread, this one way too old and long .
DJayAce
2004 - 2008 F150
18
Mar 23, 2025 06:19 PM
F150Torqued
2004 - 2008 F150
Dec 18, 2023 02:12 PM
tommy75703
2004 - 2008 F150
96
Apr 3, 2019 12:44 PM
nicholas116
2004 - 2008 F150
Dec 28, 2016 07:15 PM
Simont122
2004 - 2008 F150
Apr 26, 2016 11:26 PM
