Default gear E40D
Old Feb 25, 2011 | 11:50 AM
subford's Avatar
subford
Default gear E40D
IF all wiring is cut from the E4OD from what I have read it will go to high pressure and go to the default no power gear to get to a shop.
Now dose anyone know what the default gear is for an E40D?
From what I see in the the E4OD Reference Manual diagrams it should be 4 gear (OD) but I may not be thinking right on this one.
I would be guessing 2nd gear but the diagrams show ON & ON for the solenoids in 2nd gear.
Does ON mean no power to the solenoids?
It also shows ON means the oil will flow through the shift solenoid.
I was reading about the no power to the transmission in the following writeup about LIMP mode:
AutoTrans Articles - What is Limp Mode?
Thanks
Old Feb 25, 2011 | 08:44 PM
rclarke's Avatar
rclarke
When all electrical connectors are removed from an E4OD or 4R100 you will have 2nd gear in manual 2 shift position and 4th or OD in drive position. Reverse will also work.
Old Feb 25, 2011 | 09:50 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
What he said ^.
When the manual says a solenoid is ON, that means it is powered. Off is non-powered. The pressure control solenoid (EPC) defaults to maximum pressure with no electrical power.
f100guy
62
Feb 2, 2026 04:15 PM
tbon63
Jun 20, 2021 04:14 PM
1993 f150 4x4
Sep 7, 2016 02:19 PM
spottedsquirl
33
Sep 11, 2015 08:59 AM
plowboycowboy
Jul 20, 2015 07:44 PM
