C-6 adjustments
Old Feb 5, 2011 | 09:31 AM
brownfoot's Avatar
brownfoot
C-6 adjustments
Just had the c-6 in a '73, 2 WD F-250 rebuilt.
Engine is a 460, 3.31 Dana rear and 7.50 x 16 (32") tires.
The shifting manually is fine and under close to WOT is ok, just a little quick or maybe should say early as it is in 3rd by 40 mph.
There is a new modulator, and it has been adjusted to several positions without really changing anything.
It appears that the governor is not building enough line pressure to hold the shift points like it should. It is the same governor that was in it before, but I doubt the original to the truck, as are many parts...........
Is there a governor spring assortment to adjust the governor like is available for the GM trans?
And some kind of instructions as to what to change to change things?
or is there a way to get the proper new springs for the governor for this truck??????????
Old Feb 5, 2011 | 09:52 AM
jk080's Avatar
jk080
Transmission Rebuilder
Are you trying to get it to shift later at normal throttle?
Old Feb 5, 2011 | 12:33 PM
brownfoot's Avatar
brownfoot
yep, right now it shifts 1-2 -3 almost without detection with light throttle and will not come back to 1 without almost stopping
adjusting the modulator has had little to no effect
I am using type F fluid, all 13 quarts of it to fill it, new torque converter......
my understanding is the governor is not letting it build enough pressure?????????
Old Feb 5, 2011 | 08:26 PM
stuart1's Avatar
stuart1
Governors don't build pressure but yours could be hanging up.
If it was just rebuilt why not return it?
There may be a shift kit installed and some will result in an early shift pattern.
The modulator pin may be too short, there are 4 different lengths, longer being a higher, firmer shift point.
Old Feb 5, 2011 | 09:26 PM
brownfoot's Avatar
brownfoot
already back to shop that rebuilt it, he's gonna fix it, whether the modulator or governor or whatever, he says no shift kit installed
looking more for my understanding of what needs to be done
modulator is new, for the application, could the pin have been wrong in the new unit?
Old Feb 6, 2011 | 05:24 PM
brownfoot's Avatar
brownfoot
does anyone know the lengths of the modulator pins?
I have read that there are 4 different ones, mentioned a selective fit but no lengths???????
Old Feb 6, 2011 | 05:43 PM
stuart1's Avatar
stuart1
1.601 - 1.611
1.634 - 1.644
1.650 - 1.660
1.667 - 1.677
I use a chunk of metal coat hanger.
Old Feb 7, 2011 | 04:37 PM
zaaac's Avatar
zaaac
Originally Posted by stuart1
1.601 - 1.611
1.634 - 1.644
1.650 - 1.660
1.667 - 1.677
Nice to have a tranny expert on here helping and from Canada to boot. I went to my first airshow in Moose Jaw when I was 14. Watched the show Saturday then went to the theater and watched Top Gun(1986) that night and back to the airshow on Sunday. It was a great weekend in Moose Jaw.
Do you know of any good websites that explain the workings of the C6 and rebuilding info? Is there a book you would recommend? Thanks...Jack
Old Feb 7, 2011 | 06:02 PM
stuart1's Avatar
stuart1
Well you can always ask me.
I helped a guy in Kansas via webcam one time.
Got an all expense paid trip to Albuquerque to build a Mustang transmission.
Old Feb 7, 2011 | 06:04 PM
brownfoot's Avatar
brownfoot
well I pulled the modulator to check the pin length, yep, you guessed it, 1.673
so I have the longest pin
the trans shifts and seems to function properly if I drive it like I have boots on, but seems way too early and soft shifting when driving like I have an egg between my foot and the foot feed..............just would like it to shift more definite and not so early when trying to get a little better gas mileage...........460 is always thirsty
supposed to have the rebuilder look at it on Thursday, and he will stand behind his build, have dealt with him many times over the last 25 years so I am not worried, just curious
Old Feb 7, 2011 | 10:48 PM
zaaac's Avatar
zaaac
Thanks Stuart. My tranny may last for years so hopefully you will still be visiting this place when the time comes. Heck, my 2000 Chevy will probably need a rebuild before the Ford. I'm sure you have done many 4L60E's. I found a shop manual at the library for 67-79 Ford tranny's and it has all the specs and tests in it. Might try some of that this summer.
This book I have has the shift points. 77 Lincoln 460(no trucks in it) 3.00:1 rear end says :
throttle closed (above 17" vacuum) 2-3 shift 280-660 rpm 8-12 mph
to detent (torque demand) 2-3 shift 1220-2040 rpm 34-56 mph
through detent (WOT) 2-3 shift 2380-2730 rpm 66-75 mph
Hopefully Stuart will explain what to and through detent means and what exactly torque demand means cause I can't find any explanation in this book.
Found this explanation.
http://mustangtek.com/Library2/PDF/ShopTips3-8.pdf
What does "downshift system charged" mean? Guessing it's the kickdown rod doing its job.
Old Feb 8, 2011 | 01:10 PM
stuart1's Avatar
stuart1
TO DETENT IS WHEN THE GAS PEDAL IS PRESSED TO JUST BEFORE PASSING GEAR OR KICKDOWN IS ENGAGED.
THROUGH DETENT IS PASSING GEAR OR KICKDOWN.
DOWNSHIFT SYSTEM CHARGED MEANS THE PASSING GEAR OR KICKDOWN CIRCUIT IS PRESSURIZED.
Old Feb 14, 2011 | 08:33 PM
wasowski's Avatar
wasowski
journeyman wireman?IBEW?
Old Feb 15, 2011 | 09:37 AM
mark a.'s Avatar
mark a.
Modulator pins were recently discussed over on 460ford.com. in the driveline section. The thread is called "C6 modulator pin" by money-pit. Look at answer #4. I strongly recommend that anyone interested read this. Great imfo that clears things up.
Old Feb 26, 2011 | 02:30 PM
POPAJON's Avatar
POPAJON
stuart1, badshoe productions has video on the C6. I bought it a couple of months ago and found it informative and VERY helpful in rebuilding my C6. I put a Transgo shift kit in it while I have it out. John
