EBP SENSOR QUESTION
Old Mar 17, 2012 | 03:20 PM
BLADE35's Avatar
BLADE35
If BARO is reading PSI then at 31 or whatever PSI at KOEO its bad
Old Mar 17, 2012 | 03:24 PM
henryjb3363's Avatar
henryjb3363
I just looked at my saved file in scanner and it is definitely PSI and when vehicle is running and moving through all RPMS it does NOT fluctuate at all.
It reads 31.3 PSI ALWAYS
Old Mar 17, 2012 | 03:48 PM
henryjb3363
Where might the Barometric Pressure Sensor be Located on my 2005 6.0 F350?
Old Mar 17, 2012 | 06:27 PM
henryjb3363
I think I found a link that says it is under the dash. If someone can verify please do.
Thanks. Jim
Old Mar 17, 2012 | 07:08 PM
cheezit's Avatar
cheezit
baro reading 31 psi is an issue. but as benny said you may be in kpa and if you devide that by 1/2 its close to correct.
Old Mar 17, 2012 | 07:18 PM
bismic's Avatar
bismic
Also - 30 inches of Hg = 14.7 psi
I have a pic of what the Baro looks like in my albums somewhere ..........
Well - I guess I don't - sorry.
Here is a description:
Inside the vehicle, under the steering column (drivers side of the dash). C2256 is the connector number in the wiring diagram. Wire colours to the connector are brown with a white stripe for your 5 volt V-ref, dark blue with light green stripe is your signal wire which should have continuity between the sensor and pin #38 of the main PCM connector, and grey with red stripe coloured wire which is your signal return. This wire should have continuity with pin #33 of the PCM connector.
Remove the access panel and look along the metal brace at the bottom of the opening toward the right near the Data Link Connector... the BARO sensor is secured to the metal brace.
Old Mar 17, 2012 | 07:35 PM
bismic's Avatar
bismic
Now I do:
Ford Truck Enthusiasts Forums - bismic's Album: Miscellaneous Sensors - Picture
Old Mar 17, 2012 | 10:24 PM
m-chan68's Avatar
m-chan68
Look at your EBP, MAP and BARO readings at key-on/engine-off. Now unplug the BARO sensor and see what reading you get. Better yet, if you can borrow one from another truck to plug in, that will verify the sensor to be faulty 100%. To be honest, I have NEVER seen a BARO sensor fail, YET.
And yes, the BARO reading should remain constant from key-on/engine-off to key-on/engine-running.
Old Mar 17, 2012 | 10:28 PM
brickie's Avatar
brickie
Great post,rep ya later.
Old Mar 18, 2012 | 06:53 AM
henryjb3363
Here is a Screen Sot of my Readings notice "PSI" on all 3.
Scan of MAP, BARO, EBP | Facebook
Old Mar 18, 2012 | 12:38 PM
henryjb3363
I have removed the Barometric Sensor and started truck TURBO DEAD altogether now, no Boost reading on DASH whatsoever. Scan tool still shows 31 +/- PSI. Unfortuantely I donot have access to a used one ( Unless I run over to the Local Walmart and look for unlocked doors )
I got codes P0107 -MAP/BARO Sensor Low
U2023 -Fault received form External Node
After unplugging the BARO Sensor.
I am going to Ford to get a new Baro Sensor Monday. If is doesn't fix it
it won't be the first part I wasted money on on this truck.
Will keep posted.
Thanks
bigreentruck
Dec 13, 2016 12:37 AM
tjbradney
Jul 27, 2015 10:30 PM
WatsonR
Jun 18, 2015 08:33 AM
tommyl
Sep 1, 2014 10:00 PM
rdunagan
Mar 4, 2011 09:25 PM
