EBP/MAP reading?
Old Sep 1, 2014 | 09:21 AM
tommyl's Avatar
tommyl
EBP/MAP reading?
My '99F350 EBP is reading 14.3, and my MAP is reading 12.4. I have Superchip installed. Is my MAP sensor bad?
Old Sep 1, 2014 | 11:22 AM
white Buffalo's Avatar
white Buffalo
First , what elevation are you at? This will give you the baseline pressure to compare to, that and your Baro sensor.
2nd, are you reading the sensor data on a cold engine with key on engine off?
3rd, add the Baro sensor to the sensor list.
Old Sep 1, 2014 | 03:24 PM
tommyl's Avatar
tommyl
My other two trucks were reading close to the same numbers(14/14). That is what got me to wondering about why this truck was different. The only difference is the superchip.
Old Sep 1, 2014 | 04:45 PM
white Buffalo
Yep, all should read within .2-.4 psi of each other on a cold engine with the key on engine off - Baro, EBPS and MAP. The question is : which one is reading correct. So a good starting point is to check your Baro sensor against you standard elevation pressure.
Old Sep 1, 2014 | 10:00 PM
Tugly's Avatar
Tugly
...and pull that chip before taking a reading.
MONAVIERONJON
Jun 17, 2013 08:06 PM
Talyn
17
Jun 19, 2011 02:06 PM
Diesel and Steam
Sep 17, 2010 12:28 PM
ron's power stroke
Oct 6, 2006 09:37 PM
Dildine
Sep 26, 2001 10:32 AM
