Sponsored by: Auxito
shaking at 55mph
Old Feb 21, 2011 | 10:05 PM
arrowheadfred's Avatar
arrowheadfred
shaking at 55mph
My 03 fx4 has a bad shaking when you hit 55. The front driver side tire has started to get cups in the trend. I'm guessing if i rotate the tires and put the bad tire on the back it will stop. Lots of trend on it still. But whats wrong with the frontend ? SHOCK maybe ? If i put new shocks i was thinking of useing front ones with a spring . They say it will raise the front 1''to11/2'' . This would level the truck. Was going to get the leveling key BUT if i can get the same from these shocks that would be great. ANYONE RUNNING THESE SHOCKS ? Will i need to change anything else if i do this ?
Old Feb 22, 2011 | 09:37 AM
brokenleg's Avatar
brokenleg
you might have a bad tire. those springy shocks are a joke. shocks to not raise vehicles. yeah, they made air shocks too, but the shock mounts will break too because they are not designed to carry weight. if you want to raise your truck, do it the right way---springs.
Old Feb 22, 2011 | 08:37 PM
steve(ill)'s Avatar
steve(ill)
cupped tires means alignment problme. either the toe in- to out is bad, or the lower ball joints are shot and allowing the miss alignment. Springs and shocks dont fix alignment problems.
bobsplus
6.7L Power Stroke Diesel
Apr 14, 2012 09:14 AM
cw0187
2004 - 2008 F150
May 6, 2010 01:05 AM
Freak4Ford
Sep 5, 2008 03:40 PM
kickstarter
Jun 27, 2007 12:05 AM
Teroy
Oct 11, 2003 05:09 AM
