Sponsored by: Auxito
drivetrain or suspension vibration?
Old Feb 21, 2011 | 09:05 PM
richard stone's Avatar
richard stone
2000 F-150 4X4, 5.4L, 3:55 LS, 209K. I have a occasional vibration coming from what appears to be the rear end but unsure. It occurs when turning left or right from a stop, and usually happens when the truck has been driven for a while, not when its "cold". All the wheel bearings and U joints are tight. Only thing I have been able to find is a worn idler arm and the rear end was low on diff fluid (leaking pinion seal). Had the dealer check it out while getting some other work done, only thing they could narrow it down to was the idler arm but I can't see that being the cause of it. (they never felt it on a test drive) I will be fixing both of the items, but was wondering if anyone has ever had the same issue. My fear is the rear end but just can't figure it out, mainly because it only does it as the truck has been driven.
Old Feb 22, 2011 | 08:42 PM
steve(ill)'s Avatar
steve(ill)
you have a limit slip rear end. There is a clutch pack that slips when you turn a corner. They put regular gear lube in the alxe and the clutch is dragging when you turn. You need to add a bottle of friction modifier. You can get a 7 oz bottle at Auto Zone, or dealer can add it.
Old Feb 22, 2011 | 09:30 PM
richard stone
It should have it in it, as the rearend was rebuild about 30K ago. But, I am going to drain and refill it tomorrow and add the friction modifier. Hopefully that fixes it!
MobyDick22
1997 - 2003 F150
Jun 2, 2012 09:29 PM
onyxxtreme
Jul 14, 2011 07:06 AM
150mudder
1997 - 2003 F150
Nov 21, 2007 09:34 PM
daveinwestland
May 10, 2006 10:31 AM
tb40nd
16
Oct 2, 2005 05:10 AM
