steering column
Old Feb 19, 2011 | 08:57 PM
zombiefied 247's Avatar
zombiefied 247
steering column
I'm still learning here please be patient. could a steering column from a 84 mustang be used in my 55 f100 without to much fabricating and cutting up????
Old Feb 19, 2011 | 09:30 PM
havi's Avatar
havi
I'll have the Roast Duck
AFAIK, the Mustang column is too short. But where there's a will, there's a way. The Mustang dash also sits lower than a pickup, so I personally would look for something from another pickup or van. 70's Chevy van's were popular, IIRC.
Old Feb 19, 2011 | 11:08 PM
carnut122's Avatar
carnut122
Yeh, what Havi said.
Old Feb 20, 2011 | 12:51 AM
52 Merc's Avatar
52 Merc
Most newer cars have steering columns that are really fat or have a lot of shrouding around them. That makes them very bulky and look out of place in an older vehicle. That's one reason why the aftermarket colums have become so popular. They incorporate all the modern features we're looking for into a compact, somewhat original-looking package.
Old Feb 20, 2011 | 06:42 PM
verch101's Avatar
verch101
Anyone else have a good idea about steering column for a 1949 f1? I also don't have a usable steering box, at least without replacing the worm gears. Is there a good donor truck that I could find both in?
Old Feb 21, 2011 | 07:47 AM
snook715's Avatar
snook715
Are you keeping the stock suspension? What's your price range? What features do you want?
If so you have a few options including finding rebuilt or oversized steering boxes and OEM steering wheels/columns. You could always use a collapsible steering shaft to account for movement of your suspension and attach an aftermarket steering wheel to what ever column you use.
If you are doing something like an IFS than you would want to find a column that is not too wide and roughly 30-34 inches long depending on your seat, preferred driving position, and wheel. Although aftermarket companies like flaming river and ididit are expensive it is an important part functionally. I was patient and got my chrome, tilt, flaming river column with dress kit and joints for half price because I took advantage of shopping the interwebs.
If you're not in a hurry dont rush it. They both look cool and function well if done properly and safely. Safety first! You don't want to go down the road and have your wheel fall off and loose steering.
Old Feb 21, 2011 | 09:21 AM
verch101's Avatar
verch101
I'd like to not spend more then a few hundred dollars. A few being hundred being about 600$. Although that may not be possible. I am going to use the stock suspension, but will rebuild and replace anything that looks too shabby. I am most worried about finding a good replacement for the steering box. Am I better off trying to rebuild the orginal box? Or is there a good replacement that a lot of people on here use. What are yall running?
The box was ok when I got the truck, but like many things on this truck its something I messed up. Looks like this is going to be a costly mistake.
Old Feb 21, 2011 | 10:24 AM
AXracer's Avatar
AXracer
The Toyota PS swap is perfect for you.
Toyota Steering Box Swap For 1948-1960 Trucks .: Articles
Well within your budget even with an aftermarket column (paint grade). Search Car-Part.com--Used Auto Parts Market for a used Toy box, they go for 75.00-125.00
Mid Fifty www.midfifty.com will buy your original box, and their swap kit is first rate.
Old Feb 21, 2011 | 01:10 PM
agronomistont's Avatar
agronomistont
I used a steering column from a 79 f150 but had alot of problem with clearence on exhaust manifolds .In the end i could make everything work well so it got replaced with ididit column , but i am using the brake pedal from the 79 f150. If u can find a tilt column that would work beter
Old Feb 21, 2011 | 01:12 PM
verch101's Avatar
verch101
Thanks AXracer, this is definitely the way I am going. I think I may look for a non power-steering unit. But I will probably just take the first good unit I find. Thanks this was one of the bigger issues I was worried about. Now I just need to find a good column that will fit in the truck.
Old Feb 22, 2011 | 10:14 AM
AXracer's Avatar
AXracer
I used an Ididit tilt column in plain steel (paintable, I really didn't want a chrome or polished SS, the steering column is not that "attractive" to draw attention to it IMHO). I would highly recommend the PS box over the manual, just the right amount of assist, plus the manual box uses a different spline than the PS, and since no one offers a ready made pitman arm for the manual box you would need to make your own. The PS boxes are readily available from the link in my first post, and you could get an inexpensive pump from there as well.
Old Feb 22, 2011 | 04:53 PM
52 Merc's Avatar
52 Merc
Just to add to AXracer's comments about power steering, it would be a lot of work and expense for absolutely no gain to swap the Toyota manual steering in place of the stock stuff. If manual steering is what you desire, simply buying a reman stock steering box would be the easiest and most cost effective way to achieve your goal. You may have noticed in the stock set up, the box and column is all one unit. To change away from that means replacing both box and column separately, and then figuring out how to make it all work.
Old Feb 22, 2011 | 05:03 PM
Rhodster56's Avatar
Rhodster56
I've got a Flaming River tilt column. It's a bit overkill on the looks, but it's a very solid unit. Indicator switch return is excellent as well as the operation of all the levers. The tilt feature is very smooth. The best part about it is the adjustment range during install. You can use it at stock height or fully customized. It is expensive, but a stout product.
Old Feb 22, 2011 | 07:20 PM
snook715's Avatar
snook715
I have the glaming river chrome tilt column too. I love it but it is expensive
Old Feb 22, 2011 | 07:30 PM
AXracer's Avatar
AXracer
I wouldn't go so far as to say there is no benefit to using the Toy manual box, the recirculating ball design is far smoother and wear resistant than the antique design Ford carried over from the Model T, but the very small/no savings over the PS version is hardly worth the effort to use the manual box.
SeaCarr
Feb 10, 2015 10:51 PM
rwrogers
Jan 29, 2014 06:58 PM
RTaylor65
Jun 20, 2013 08:43 PM
bertke2651
Mar 16, 2012 01:04 AM
Skip1970
Jul 24, 2009 12:52 AM
