ATS 085 vs. ATS 088
Old 02-19-2011, 05:36 PM
1lowscort's Avatar
1lowscort
1lowscort is offline
ATS 085 vs. ATS 088
What are the differences and pros and cons and such to these two setups? I currently have the ATS 085 on my 88 F350, however as I work at a junkyard, I pulled an 088 out of a truck last fall. Is one better than the other? I have been trying to figure this out for months!
Old 02-19-2011, 05:54 PM
oreocreaming's Avatar
oreocreaming
oreocreaming is offline
088 is wastegated. much better turbo. higher boost at better control with less chance of engine damage
Old 02-19-2011, 06:02 PM
1lowscort's Avatar
1lowscort
Are you sure the 088 is gated? I know the 093 is, but I don't remember the 088 having a gate on it when I pulled it.
Old 02-19-2011, 06:37 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
FORDF250HDXLT is offline
Old 02-19-2011, 06:58 PM
1lowscort's Avatar
1lowscort
I have all of the PDF files, but I still don't know which is better, if either are bigger, etc. also, has anybody put an intercooler on either of these systems?
Old 02-19-2011, 10:16 PM
snaponprofile's Avatar
snaponprofile
snaponprofile is offline
If neither the 085 or 088 systems are wastegated, you won't see much gains from switching from 085 to 088 - You will see gains from switching to the 093 system. Oreo had the 093 if I'm not mistaken and he had it intercooled. You can see over 10 psi with those(with proper DP/turbine housing) 093's without much trouble.
Old 02-20-2011, 01:00 AM
88beast's Avatar
88beast
88beast is offline
the 93 is gated
the 85 and 88 are practally the same and usually the 85 is grouped in with the 88
a gated turbo will make more boost and make it lower in most cases so the 93 is worth it but an 85 to 88 is pointless you wont notice it
Old 02-20-2011, 11:29 PM
1lowscort's Avatar
1lowscort
Excellent! That is what I needed to know. Thanks folks!
ThePriceLife
06-18-2017 10:19 PM
joursleridi
09-27-2016 08:54 PM
6.9lXLTf250
07-18-2016 04:51 PM
1973dieselhighboy
02-22-2011 09:33 PM
Azguy54
05-26-2004 01:05 AM
Quick Reply: ATS 085 vs. ATS 088
