ATS 085 vs. ATS 088
ATS 085 vs. ATS 088
What are the differences and pros and cons and such to these two setups? I currently have the ATS 085 on my 88 F350, however as I work at a junkyard, I pulled an 088 out of a truck last fall. Is one better than the other? I have been trying to figure this out for months!
on
085
https://www.atsdiesel.com/PDF/6.9-08...yout-sm-A1.pdf
088
https://www.atsdiesel.com/PDF/6.9-7....yout-sm-A4.pdf
waste gated 093 (basically the factory option in '93 and '94)
https://www.atsdiesel.com/PDF/7.3-WG...yout-sm-A1.pdf
088
If neither the 085 or 088 systems are wastegated, you won't see much gains from switching from 085 to 088 - You will see gains from switching to the 093 system. Oreo had the 093 if I'm not mistaken and he had it intercooled. You can see over 10 psi with those(with proper DP/turbine housing) 093's without much trouble.
ThePriceLife
06-18-2017 10:19 PM
6.9lXLTf250
07-18-2016 04:51 PM
Azguy54
05-26-2004 01:05 AM
085, 088, 093, 20, ats, classifieds, difference, eugene, exhaust, housing, intercooled, intercooler, kit, online, oregon, powered, rebuild, smf, turbo, works
