2002 x V10 4WD Front Hubs
I am a little confused on the proper operation of the auto front hubs. I have the hubs set to auto and when switch is on 2WD the universal joints close to the front wheels spin with the wheel. I was wondering if this is correct or should they disengage?......thanks in advance for info
Here's a great write up on maintenance for the hubs
Welcome to guzzle's 4x4 Autolock Hub Lubrication Maintenance Web Page
All the stuff he has written up from a maintenance standpoint is here:
Welcome to guzzle's Ford PSD Maintenance Web Page
2002 X,
I recently purchased my 2003 EX and found that the front axles were defintely turning even though it was in 2HI and the hub was unlocked.
I knew this was not right and informed the super duty tech of this.
When I had the ball joints replaced, the tech cleaned, lubed and replaced the axle seals and o-rings.
He also told me that not only is vacuum utilized to lock the hub, but also to unlock the hub. Anything not sealed, lubed or working correctly can make the locks stick in a locked position after having it in 4HI.
After he completed all the repairs, the axles are free and now the vacuum works properly to lock and unlock.
Good luck in your quest for free axles.
I'm sure when free, gas mileage will be a little better, and there will not be excessive wear on those front end parts.
on the passenger fender wall behind battery is a solenoid that controls vacuum to the hubs. pull the hose off to the wheels and suck it like a straw. you'll know if you have leaks then. mine had a leak on the y splitter down on the cross member where it seperates to both wheels. it would lock but wouldnt unlock. had to pull the hub and unlock it by hand. after fixing the leak it works fine
It very well could also be the solenoid is bad. I hear its a very common problem with the solenoids. Works like this... when the dash switch is moved the solenoid should apply vacuum for about 45-60 seconds to lock hubs and to unlock it does the same again just with less vacuum. there are more detailed innstructions in this forum on exactly how this systems works. I was in your shoes not long ago.
ron01sd
15
01-03-2008 12:48 AM
