UNSUCCESS - my problems continue.
Old Feb 14, 2011 | 07:22 AM
  #61
powersmoked's Avatar
powersmoked
Originally Posted by wp120470
Unsuccess. This is my first chance to join in and truly enjoy the friends of this wonderful club. I have read all the post on this matter and as a fleet mechanic with 50+ rangers I have a couple of questions for diagnosing purposes. First, When you are accelerating and holding it to the floor will the truck give you a sudden burst of power after around 2,000-2,500 RPM range? If so something to check is your Casmshaft Position Sensor. Try this to see if any improvement will occur. Take a can of carb cleaner and kneel down beside your drivers side front tire. You should see the cam sensor mounted on the block right behind the oil punp that is driven by the timing belt. Spray it down with the carb cleaner and see if it improves idleing immedietly.If so, you may have a seal leak in the oil pump causeing your problems.It sounds crazy but give it a try. Let us know the results.
WP120470. I thought only the 1994 2.3 CA trucks had the Cam sensor? Does he have a CA truck? he is in NC?
Old Feb 15, 2011 | 12:32 AM
  #62
danielwd's Avatar
danielwd
This was a question I raised at Autozone and other places to no avail. My truck is from Livonia MI, at least that's where the sticker says it was manufactured.
I was under the impression that my truck did not have a cam sensor because it is not a CA truck per Haynes Manual. And the trucks that do have the cam sensor I believe rely on that auxillary pully for "sense".
Old Feb 15, 2011 | 07:36 AM
  #63
03 Maz B23's Avatar
03 Maz B23
Here is a good link that I like to use only for reference on Ford parts which shows parts and related parts with some diagrams to help pinpoint their location. Enter vehicle information and choose category once you get in. I wouldn't sweat the crankshaft position sensor at this point. If after you replaced your ICM you still had problems then you would have to check into it. You clearly solved that problem so that's a non issue now.
Ford Parts | Buy Official Motorcraft & Genuine OEM Ford Parts Online | FordParts.com
spthomas
2004 - 2008 F150
Nov 24, 2015 12:45 AM
AnnoyedEasy3
Bronco II
Mar 30, 2015 01:12 PM
SageofHalo
2004 - 2008 F150
Jun 20, 2014 06:04 AM
njjr
Apr 21, 2014 12:09 PM
MacWilliamFamily
New Member Introductions
Nov 10, 2009 04:37 AM
