Lock Punched
Old Feb 13, 2011 | 06:19 PM
  #61
W7PSK's Avatar
W7PSK
Veteran: Navy
Originally Posted by sdetweil
you have to pull the tailgate loose from the right hinge to get the band around the pivot..
Sam
I am doing the right But I cannot get the band to stay in place to wrap around the pivot.
It keeps going under the door or it hangs up under the pivot without coming through.
Old Feb 13, 2011 | 06:59 PM
  #62
sdetweil's Avatar
sdetweil
I did open it up a bunch and set it around the body side, pointing up towards the top of the bed, then set the tailgate on it.
Maybe I can take pic tomorrow
Sam
Old Feb 14, 2011 | 09:13 AM
  #63
11350KINGRANCH's Avatar
11350KINGRANCH
I slid the tailgate off of the pin, put the lock on the barrel with the opening faced towards the pin, then put the tailgate back on and spun the pins around to lock it. It took a little forcing to get it spun around, but it will.
Old Feb 19, 2011 | 08:13 AM
  #64
BIRDMANN79's Avatar
BIRDMANN79
Originally Posted by Adobe 11SD
I'm lazy tonight and just briefly read the replies, but am not sure what you would do in the event of dead battery/batteries.
Without battery power the remote (or keypad) does not work and I'm not sure how you get into the truck to release the hood latch so that you could replace them - if you deleted the key cylinder.
This is very easy solution especially on a truck ....instead of jumping the battery you just climb under the truck and put the positive cable onto the starter ....I had to do this on an expedition ..took about 5 seconds and bam the keypads were all powered up .....
Old Feb 19, 2011 | 11:00 PM
  #65
PITS's Avatar
PITS
You can also add a piece of heavy insulated wire to the + of your battery and drop it through the engine compartment. Insulate the end well and secure it to something you can get to from under the truck. Then if everything goes dead (very unlikely) just hook up another battery with jumper cables or a charger to this wire and another to your frame and you will have enough power to at least open the door locks with the remote or keypad.
Old Feb 20, 2011 | 02:01 AM
  #66
BigPigDaddy's Avatar
BigPigDaddy
I just added a big screen nav unit.. now an attractive item
Just make sure your rifle is sighted in for whatever distance your truck is from your bedroom window at night.
Old Feb 20, 2011 | 10:41 AM
  #67
farmerdave's Avatar
farmerdave
Pickup truck+chain can rip the doors off any garage door. That doesn't mean I'm going to leave my garage open or unlocked.
I hate thieves. I want to make their job as difficult as possible.
Old Feb 20, 2011 | 10:57 AM
  #68
lexustbs's Avatar
lexustbs
YouTube - WORLD'S BEST ANTI-THEFT SYSTEM
Shoot, I'm getting one of these! What if this bad boy activated going down the highway. Death Wobble anyone? I can't stop laughing over this one.
Old Feb 20, 2011 | 11:31 AM
  #69
farmerdave's Avatar
farmerdave
http://m.youtube.com/watch?gl=US&cli...&v=_zDhois8Io8
I know the 2010 super dutys are about as easy as these ford rangers and we have the same door handles.
I like the Death Wobble accessory!
Paul98038
1997 - 2003 F150
Dec 31, 2019 03:57 PM
boywonder
15
Sep 20, 2019 11:19 PM
brian42
Oct 27, 2016 05:38 PM
AZ_Mike
Oct 23, 2016 04:36 PM
roostonu
May 5, 2006 03:03 AM
