Trip Odometer and Compass
I have this same problem but only when my truck sits out in the sun for a while on hot days. I'm interested to know what it might be as well.
I think the only thing we've seen is a blown bulb...
There's a thread- fairly recent that dealt with removing the cluster to check/change the bulb.
Could even be a connection was jarred loose.
I'll see if I can find it...
I went back 2-pages and found this: https://www.ford-trucks.com/forums/8...-odometer.html
It has to be light (as opposed to heavy) connections behind the instrement cluster. I haven't had to remove mine on this truck, but on other vehicles I've owned, they have a plactic plug that fits into the back of the cluster. After awhile the plastic looses it's tension and results in poor contact if any at all. A good certified shade tree mechanc should be able to come up with a fix.
2004-08 F150 ODOMETER/COMPASS REPAIR
IS THE ODOMETER COMPASS BLANK OR INTERMITTINT OR NOT WORKING CORRECTLY?IF YOU ANSWERED YES ,I HAVE THE SOLUTION FOR YOU.REPAIR SERVICE TO REPAIR YOUR INSTRUMENT CLUSTER FOR THE FOLLOWING....
ALL 2004-2008 f-150 pk only
WE ONLY OFFER REPAIR ON THE ODOMETER/COMPASS/TEMP THIS WILL WORK FOR YOU............IVE REPAIRED OVER 6000 CLUSTERS
CALL ME @479-652-2258
BRIAN'S SPEEDOMETER REPAIR
