im almost sure its time to rebuild the old 460 any ideas on cheap rebuild kits or maybe ideas on what happened would be nice it has a knock at 2500 rpms but no power loss or smoke and good oil pressure just the bottom end knock this is my first 460 have had a few fords none with this many problems.
Trying timing u can time a motor and itll ideal fine but drive itll it make aaknocking noise. But worst case crank bearing is starting to go and summit has great kicks starting at 400 for a small block sure its a liitle more for a big block. Can get differnt ones that include vareas things
If it's 20+ years old there's no doubt it's worn out.
Plenty of master rebuild kits on Ebay as well.
If you have cheap access to a machine shop it would be smart to do as much cleanup work as you can before ordering anything.
Otherwise, a remanned longblock will likely save you both time and money.
I agree take it apaort before u order if thats what u decide to do. Have every thing miced so no if u have to get over orundersized bearings. Or have to hone or bore the block.
Only my opionion no ebay ive had bad experiance but dosent mean u will.
