Knock sensor for a Speed Density 460?
Old Oct 14, 2002 | 07:30 PM
LxMan1's Avatar
LxMan1
Old Dec 16, 2002 | 01:56 PM
genspot's Avatar
genspot
Hi all,
Has anyone tried to install the 5.8 litre knock sensor on a 460?
Looking over the wiring diagrams for my '88 F350 I notice that there is a port on my trucks computer that accepts the input from a knock sensor on the 5.8 litre, but is not used for the 460.
Has anyone tried to install the 5.8 litre knock sensor on a 460? If so can you let us know where you put it and how well it worked?
thanks and Merry Christmas to all!
R.
Old Dec 18, 2002 | 01:50 AM
phantom429's Avatar
phantom429
Well I wouldn't really bother unless you have a knock problem, but anyhow. If you have a knock sensor pin on your PCM you can try and hook up a knock sensor to it. A knock sensor must bee screwed directly into the water jacket of the block in order for the knock to resonate with enough force to cause the chrystal to emit a voltage. If you can do this and hook it up, it may work.
Nick from the frozen north
1974 F-250 4X4
soon to be 429
dana 60 front and rear
Old Dec 24, 2002 | 12:12 AM
LxMan1's Avatar
LxMan1
in a water jacket? Most of them that I have seen screw directly into the block.
Old Dec 24, 2002 | 07:19 PM
phantom429's Avatar
phantom429
The water jacket is in the block. The cylinders are surrounded with water, or in a jacket of water so to speak. When ever you pull out a knock sensor, antifreeze will also run out of the hole. This is because the water transmits the shockwave from the cylinder to the sensor.
1974 F-250 4X4
soon to be 429
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
