Testing Sending unit/fuel guage
Old Jan 30, 2011 | 08:25 PM
mr_ranger-79's Avatar
mr_ranger-79
OK, I just put a new sending unit in my rear tank and the tank is working fine, but the fuel gauge still doesnt work. When I unplug the electrical connector that connects the sending unit and put a wire tester on it it blinks. According to the information that I have, that is what it is supposed to do. So I believe that tells me that I have power going to the unit like it is supposed to be. So, I am beginning to assume that the connector itself is worn out. Does this make sense? I thought about simply going to Autozone and picking up a couple of round female connectors to atleast test it with. Any ideas/suggestions?
Old Jan 30, 2011 | 10:07 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Just ground the sending unit wire to the frame and the gauge should peg FULL. If it doesn't the gauge is faulty.
Josh
Old Jan 30, 2011 | 10:32 PM
mr_ranger-79
My gauge works just fine with my front tank.
Old Jan 30, 2011 | 10:38 PM
Bullitt390's Avatar
Bullitt390
Would have been good to mention that in the OP, yes?
Josh
Old Jan 31, 2011 | 12:09 AM
mr_ranger-79
My apologies...yes I should have mentioned that. I just don't see how it is possible that it is anything but the connector itself. I suppose it is possible that I got a bad sending unit.
Old Jan 31, 2011 | 12:14 AM
78 PEB's Avatar
78 PEB
Like bullit said.................If you ground the wire coming from the guage back at the connector for the tank and the guage pegs............you have virtually eliminated any other problems from that connector forward to the guage............If that checks out good its from the connector to the sending unit or the sending unit itself......
Old Jan 31, 2011 | 02:43 PM
mr_ranger-79
OK...so here is what I have. If I put a test light on the wire coming from the gauge the light blinks strong. If I hook a ground wire up to the wire coming from the gauge the gauge doesnt move. Does that mean the gauge is bad? I am going crazy here! Neither tank has much fuel in it, but should be enough to register on the gauge. I am considering going down and dumping more fuel in both tanks to ensure the gauge still does work for the front (it was working fine). OK, so the gauge works just fine on the front tank. Am I to assume the brand new sending unit that I just bought is bad? OK...figured it out finally. I just didnt have a good enough ground so I made a brand new ground straight off the frame.
Old Jan 31, 2011 | 06:35 PM
Bullitt390's Avatar
Bullitt390
Are you testing at the gauge, the switch, the valve or at the sending units?
Green/Red should be rear tank
Black is front tank
Brown with white tracer is the valve.
AT THE SENDING UNIT if you ground either wire with the switch in the correct position it SHOULD pef the gauge to FULL.
If it doesn't work at the sending unit that is when you start working your way back to the switch on the heater control panel.
Or do you have an aftermarket style? Some of those are mounted on the floor board by the seat.
Josh
Old Jan 31, 2011 | 10:55 PM
mr_ranger-79
It is all fixed now. I was testing it back at the rear tank since the front tank worked fine. It turned out I just had a bad ground. I sanded the frame nice n clean and put a new ring terminal on the frame cross member and now it works perfect.
Old Jan 31, 2011 | 11:07 PM
Bullitt390's Avatar
Bullitt390
Schweet!
Keep on truckin'
Josh
Old Jan 31, 2011 | 11:20 PM
mr_ranger-79
Thanks for your help. I appreciate it.
Old Mar 22, 2011 | 08:44 AM
Turx's Avatar
Turx
Are we talking about grounding the tank itself?
Both my 97 and 92 have front tank gauge issues. Both tanks work, but the gauge reads "E" on both even when they are full. If it's a short the gauge goes past "E", sending unit problem it just goes "to" E, correct?
Old Mar 22, 2011 | 10:23 AM
78 PEB's Avatar
78 PEB
There are two wires that come off of the sending unit. One runs up to the guage, the other is a ground that hooks to the frame. I beleive he is referring to the ground that attaches to the frame.
Old Mar 22, 2011 | 10:59 PM
fmc400's Avatar
fmc400
MSEE
I'm fairly positive that sometime after the 73-79 generation (not sure how much later), the sending unit direction was reversed. You should post these questions in the Electrical forum or the forums for your '92 and your '97, as the principles for 73-79 won't apply.
Old Nov 9, 2022 | 09:07 PM
Roland Malschafsky's Avatar
Roland Malschafsky
1st Gear
Thumbs up 79 F250 Rear fuel tank
I have a similar problem. The front tank reads accurately. the rear tank has a new sending unit and after fill up (19 Gal) it shows full. then after 25 miles it shows half full...?? i go back to the filling station and it only needs 3 gal. I did clean the ground wire connection to the frame thoroughly and still have the same problem.
Any ideas , suggestions to help me work out this glitch
many thanks to all
diesel77
Jul 28, 2020 11:52 PM
cumminsswap
Nov 4, 2015 05:59 PM
jim collins
Oct 10, 2015 08:25 PM
jrockdiddy
Jul 23, 2015 09:44 AM
Anafiel
1978 - 1996 Big Bronco
Feb 28, 2011 05:02 PM
