E4OD Transmission problems - advice please!
Old Jan 26, 2011 | 05:12 PM
lcattin's Avatar
lcattin
I have a 94 f150 XLT x/cab 4X4 with a 5.0. The truck has 260,000 miles on it. I do not know the milage on the transmission as I wouldn't think that it was original. When I got it the fluid was burnt so I drained the TC and the tranny and changed the filter. It was having occasional issues shifting into OD but worked well otherwise and doesn't seem to slip even towing 4000 lbs. The TC is now throwing a slippage code and the shifting into OD is getting worse. My quandry is do I just change out the TC and see what happens or try to rebuild the E4OD also. Don't want to dump a bunch of unnecessary funds into it although it is a nice Arizona truck. What special tools would I need to rebuild the one I have? What would you do?
Thanks,
Les
Old Jan 27, 2011 | 06:48 AM
Scndsin's Avatar
Scndsin
Its time for a rebuild. Just a new TC is not going to do it for you. If your level is correct, drain off a quart & replace it with Lucas Trans fix & that may clean up your issues for a while, giving you time to work through your choices.
Google is your friend or use the advance search function at the top. Rebuilding the E4 correctly is not for the faint of heart or the average in mechanical skill. Your going to spend 1-2K$ minimum + a new converter (300-$600) regardless of the quality of the build.
Hope this helps & good luck.
Old Jan 27, 2011 | 06:59 AM
fdude64's Avatar
fdude64
i had a 94 f150 that was slipping i traded it to a guy that put the additive for the limited slip rearends in it and it quit slipping and lasted another two years
Old Jan 27, 2011 | 08:57 AM
96f350az's Avatar
96f350az
^^^i did the same. sold my buddy a ranger that had a bad shift into 2nd he filled it half w the stop slip from lucas and its better. not sure if its good for it but its been fine for the last year/half
Old Jan 27, 2011 | 10:14 AM
lcattin's Avatar
lcattin
Thanks all. I am currently looking for a used transmission also. Found one with a 30 day warranty so I may try it out. I did put in a bottle of TransX but I don't know if that helped or not. The trans doesn't seem to slip but the converter lock up does according to the code that the computer threw.
Old Jan 27, 2011 | 10:27 AM
Lazy K's Avatar
Lazy K
https://www.ford-trucks.com/forums/1...ding-e4od.html Have a read hear for rebuilding info.
Old Jan 27, 2011 | 08:59 PM
lcattin's Avatar
lcattin
Will an E4OD from a 460cu engine fit a 5.0?
Old Jan 28, 2011 | 12:53 AM
CJM8515's Avatar
CJM8515
Wrong bellhousing
Old Jan 28, 2011 | 06:39 AM
lcattin's Avatar
lcattin
Thanks I was afraid of that.
Old Jan 31, 2011 | 11:30 AM
lcattin's Avatar
lcattin
Can anyone please tell me what years of E4OD will fit in my 94' 4x4 with a 5.0?
I am at work so don't have time to do a bunch of research.
Old Jan 31, 2011 | 11:50 AM
SideWinder4.9l's Avatar
SideWinder4.9l
1992-1996 F150's with a 300,302, and 351 all have the same bolt pattern (Bellhousing) for the E4OD....
Then you get into whether or not your truck is 4x4, etc...
.Hopes that helps...
-Wes
Old Jan 31, 2011 | 11:53 AM
lcattin's Avatar
lcattin
Thank you! It does, a lot.
Les
Old Jan 31, 2011 | 11:57 AM
SideWinder4.9l
No prob...
-Wes
mototrig
69
Jul 4, 2014 10:53 AM
Red454sedgwick
Ford Truck Parts for Sale
Apr 24, 2014 09:42 PM
Scaper
29
Apr 7, 2012 11:37 AM
snaponprofile
19
Oct 18, 2011 08:53 PM
78f3504x4
Jun 26, 2008 03:28 PM
