shakeing while driving
Old Jan 28, 2011 | 07:40 PM
Big-old-460's Avatar
Big-old-460
hi sry back... I have read all the post and so far ... with out being there.... If you swear u do not feel it in the steering wheel.... it totally sounds like a suspension issue of some sort.. from bent axle to , bent drive shaft etc .. when did you noticed this shaking, and what did you do to the truck prior to the shaking, did u go off roading , or jump it or hit anything etc ...
let me know... also what have you done to inspect this you self ...
jayson
Old Jan 29, 2011 | 09:15 AM
96f350az's Avatar
96f350az
i bought the truck haha. thats what i did before i noticed it.
i only took it to 60 when i test drove it. on the way home noticed the vibration. lesson learned. well i would of bought it still who am i kidding.
i dont think the previous owner was much of a desert running rally racer so dont think it was jumpped or ran through anything it couldnt handle.
and ive checked everything under the truck for looseness and tightned what needed tightend.
its in my seat not the wheel. its a slow bucking at 35-40. so up an down like aan out of shape tire. then 70 is just a mess. but goes away after 75 and happens around 73
Old Jan 29, 2011 | 02:43 PM
Cheapteen979's Avatar
Cheapteen979
Same problem, kinda. Except mine just jeeps getting worse after around 75ish. And I had my driveshaft and all u joints i'n it checked. I'v never jumped it or anything serious just loads of mud. I've buried it to where mud was a little over the axles and I had a full night of drunken fun trying to get it out. But I let a couple of dodges pull me out though. I didn't stress the driveshaft too much because I know there was no use i'n trying.
Old Jan 29, 2011 | 02:46 PM
Cheapteen979
And for the record both dodges were diesel 4x4 with it i'n 4 low on a county road trying too pull me out. And I broke one of there bumpers off.
Old Jan 29, 2011 | 05:35 PM
capn kirk's Avatar
capn kirk
cheapteen- I think you have a wheel issue, see if you can find a buddy with an old ford or chevy or dodge swap the wheels onto yours and go for a ride see if it still has the issue
Old Jan 29, 2011 | 07:40 PM
mmhoward's Avatar
mmhoward
I had been trying to figure out the same problem on my truck for a couple of years and finally got the problem solved. Replaced my tie rods and found that the inner/center link was bad. There was no play when checking the wheel so I did not think it was the tie rods. I have replaced almost everything else so I was running out of options. Truck drives like new after the alignment was done for the new tie rods.
Old Jan 29, 2011 | 08:05 PM
Big-old-460
well is sounds like a suspension issue on both parts,,, but Tires and rims are the back bone of any car and if you do not have the right tires and rims ... or even if all 4 tires are new and you have a heavy spot in the tire,,, that could also be the issue...
I think.... if i was you guy... unfortunately its nothing that can be pin pointed.. unless its taking to a mechanic to run some test.. I would take it in.
no sence in replaceing every part will it stop shaking,,, sry mate but i am out of ideas.
jayson
Old Jan 30, 2011 | 09:36 AM
96f350az's Avatar
96f350az
ima try tie rod ends, ill keep posted when its done
Gastic3514
Jan 20, 2013 09:08 PM
backdr10
Oct 28, 2010 11:01 AM
cactusbronco
1978 - 1996 Big Bronco
Feb 20, 2004 07:54 PM
Teroy
Oct 11, 2003 05:09 AM
Joe McMillan
May 23, 2003 11:04 AM
