transmission temp
Old Jan 27, 2011 | 04:45 PM
grizz 454's Avatar
grizz 454
transmission temp
i would love to put a trans. temp gauge in my truck. is there a good place to put the sending unit on e4od. or would someone tell me whats best. thanks everybody. and hey, just wanted to say i,ve learned a lot from you guys. and i really apreciate it.
Old Jan 27, 2011 | 05:15 PM
powerstroker100's Avatar
powerstroker100
best description I can give is theres a bolt on the driver side of the transmission just about an inch above the lip on the pan its about it the middle of the trans more so toward the engine, I think the bolt is like 8 or 10 mm, what other guys have done is plumbed it into the lines right before the trans cooler which is a better way to do it in my opinion
Old Jan 27, 2011 | 06:55 PM
snaponprofile's Avatar
snaponprofile
I put one in recently and it is a 1/8 npt fitting. The temp. sender screwed right into the port that powerstroker described.
Old Jan 27, 2011 | 07:18 PM
grizz 454's Avatar
grizz 454
does using either set up more acurate than another and can both kinds be bought at auto parts store
Old Jan 28, 2011 | 08:58 AM
snaponprofile
I got my temp gauge at a local speed shop. It came with everything needed. This is it.
Old Jan 28, 2011 | 12:53 PM
PLC7.3's Avatar
PLC7.3
The port on the trans gives you the "right now" trans temp ..........
Old Jan 28, 2011 | 04:16 PM
grizz 454's Avatar
grizz 454
thanks guys, gonna see what i can round up this weekend supposed to be 62 degress here tomorrow. sounds like a good day to put one in, after i get this roof done so i can get paid lol. thanks again my friends
Old Jan 28, 2011 | 04:56 PM
eatont9999's Avatar
eatont9999
Do you use regular teflon tape to seal the threads? How much tranny fluid is going to spill out?
I might want to do this when I get a truck.
Old Jan 28, 2011 | 05:41 PM
grizz 454's Avatar
grizz 454
good question eatont,was wondering that myself.....anybody?
Old Jan 28, 2011 | 06:42 PM
Coalroller's Avatar
Coalroller
the port is a pressure port so tranny fluid will spill out but not fast or a a lot but it will dribble out
as far as teflon tape use the higher temp one and one that is good for about 200 psi or more just as a precaution
Old Jan 28, 2011 | 07:23 PM
grizz 454's Avatar
grizz 454
thanks coalroller, good info
Old Jan 28, 2011 | 10:17 PM
Coalroller's Avatar
Coalroller
no problem man, i am currently using that port for my tranny temp and trans pressure but later (when i get free time) move my temp sensor up to the tranny cooler. But for all intensive purpose the tranny temp gauge in the pressure port is fine and works great
Bigtruc
20
Dec 26, 2013 10:24 AM
sncbluegt
6.7L Power Stroke Diesel
Dec 15, 2010 10:04 AM
gmm
Apr 8, 2009 07:11 PM
fyre82
1983 - 2012 Ranger & B-Series
Feb 16, 2006 02:09 PM
agreder
Apr 27, 2005 05:43 AM
